Author Topic: Cannot install Nvidia driver for RTX 2080 Ti in Ubuntu 18.04/16.04 LTS (X299)  (Read 485 times)
arewe007Topic starter
@page { margin: 0.79in } p { margin-bottom: 0.1in; line-height: 115% } a:link { so-language: zxx }
I am trying to install nvidia driver with RTX 2080 Ti in Ubuntu 18.04 LTS
After Installing nvidia-driver (version 418.56) , the system will not boot . The following output comes and the screen stays blinking :
Code: [Select]
/dev/sda4: recovering journal
/dev/sda4: clean, some numbers / some numbers file, some numbers / some numbers blocks
Output of following commands are :
lspci |grep -i nvidia
Code: [Select]
65:00.0 VGA compatible controller: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] (rev a1)
65:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1)
65:00.2 USB controller: NVIDIA Corporation TU102 USB 3.1 Controller (rev a1)
65:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 UCSI Controller (rev a1)
uname -m && cat /etc/*release
Code: [Select]
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.2 LTS"
NAME="Ubuntu"
VERSION="18.04.2 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04.2 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
gcc --version
Code: [Select]
gcc (Ubuntu 7.3.0-27ubuntu1~18.04) 7.3.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
uname -r
Code: [Select]
4.18.0-15-generic
I tried installing Nvidia driver through three different following methods :
Using PPA :
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo ubuntu-drivers autoinstall
sudo apt install nvidia-418
Through Nvidia site directly :
 downloaded the display driver for Linux from
 https://www.nvidia.com/download/driverResults.aspx/138279/en-us
 chmod +x NVIDIA-Linux-x86_64–410.57.run
 sudo ./NVIDIA-Linux-x86_64–410.57.run –no-x-check
Along with Cuda
Using sudo apt-get install cuda
In all cases the result is same and the system would not boot and gets stuck at the error mentioned before .
 Any help is much appreciated!!!
