Author Topic: Msi radeon VII  (Read 185 times)
realchauretTopic starter
Msi radeon VII
« on: 22-April-19, 19:36:06 »
I find kinda weird there no topic on Msi radeon VII.
After almost 2 weeks having bought one .I'm kinda scared of the temperture.
On msi afterburner I have 65 degree but on mining software it says I'm like 85 degree
hopefully I undervolted it cause i would reach easly 105 degree and more should I be worried about it ???
are there so futur upgrade drivers or stuff that well fix things or should i look elsewhere to fix those high tempeture or should I return it?
hoping for some reply to re assure me thanks.
  • 微星科技
Re: Msi radeon VII
« Reply #1 on: 23-April-19, 14:06:44 »
Actually not as there are very little numbers sold compared to the nvidia cards and mainstream RX 570/580 cards.
I'm kinda scared of the temperture. On msi afterburner I have 65 degree but on mining software it says I'm like 85 degree hopefully
These temps are very normal temperatures and what is to be expected from a Radeon VII.
The gpu can't reach that high temps as it would shutdown earlier.
Windows 10 Pro
MSI MAG BUNKER Case
Re: Msi radeon VII
« Reply #2 on: 23-April-19, 22:40:53 »
Thanks for the reply I download Hwmonitor and i can reach easily 100+ at stock volts hotspot gpu or hotspot is this little to much?
  • T9246ED, Бивша комета
  • Administrator
Re: Msi radeon VII
« Reply #3 on: 25-April-19, 08:38:21 »
those cards seems to run very hot 100C-110C range [have a high operation temp]
and start throttling at 115C
seeing similar results everywhere
etc appear to be expected temps from this GPU with that generic cooler
