Author Topic: GE60 2PG user - Help  (Read 338 times)
samwng78Topic starter
« on: 23-April-19, 21:37:01 »
Anyone can share with me your factory software image ( which comes with your laptop).
Willing to pay a little token for your time. Thank you in advance.
RaiderGamer
  • LIEUTENANT COLONEL
Re: GE60 2PG user - Help
« Reply #2 on: 23-April-19, 21:55:14 »
Thanks for your prompt reply.
Prefer to stick to original / factory software -Win8.1 with all the device drivers pre-install when reset my laptop.
« Reply #4 on: 24-April-19, 01:43:54 »
I got stuck from here.. Any clue ?
https://ibb.co/Dzmzs5M
Image uploaded here
RaiderGamer
« Reply #5 on: 24-April-19, 10:18:04 »
just wipe out your recovery partition and add the space back into either c or d using a partition tool
then shrink your c to 100GB and add the rest of the space into d
then install any games or files onto d in the future
then install a fresh 8
then install drivers apps
then use windows to take an image of c and keep it on d
annet
  • CAPTAIN
« Reply #6 on: 25-April-19, 04:32:00 »
The way that @RaiderGamer provided you is to do a clean install of OS. You need to install drivers and applications by yourself afterwards.
From you words it seems that you simply want a image file of GE60 2PG. Of course the easiest way is to contact MSI and ask them if they can do it for you if you send the laptop to their service center.
If you think it'll take long to do so, ask them if they can provide you the image file you need.
