Author Topic: Cant oc my cpu even when it says it is, msi zh77a-g43  (Read 1823 times)
waltobc2Topic starter
i got new mother-board after last one served well 6 years, always used a small oc on my i7-3770k to around 4.1 and never left the 60 C zone
now i got new msi zh77a-g43 h7 version
which after reading i should pick the z7 version for me to be able use the change clock i got from my 3770k version.
but i read that even my h7 could easly be oced to 4.0 - 4.1
i tried multiple settings over the oc section in bios, update my bios to the last version 1.A and even tried to use the  OC Geine II and yet when i run cpu burn test all 4 cpu lock at 3691, and even trying to set cpu at x39 puts it back on x37.
What im doing wrong?
HenryW
Re: Cant oc my cpu even when it says it is, msi zh77a-g43
« Reply #1 on: 24-April-19, 01:52:29 »
That board has H77 chipset which you can not OC on. For OC you would need board with Z77 chipset.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
« Reply #2 on: 24-April-19, 10:10:06 »
wait what? really? so why i got all the option to oc in bios?
i can change the bios chipset from h77 to z77 on my board with my friend which is electronic engineering, would it work or im am doomed?
i wish i know that before, cuz from what i read in MSI it was cable to oc , also i dont need a big one :()
it does jump from time to time one or 2 single core , but when i set a cpu test to load it to 100% its stuck on x37
HenryW
« Reply #3 on: 24-April-19, 11:50:25 »
The fastest you can get that CPU on that board is 3.9 GHz which is max Turbo frequency. Max CPU ratio you can get is 3.9 with that CPU. As I said the H chipsets can not OC beyond Turbo speed. Examples: H67, H77, H110 etc. You can do an internet search to confirm what I said.
Corsair TX650W
« Reply #4 on: 26-April-19, 01:59:41 »
thats why im trying to get - that the cores will work always on 3.9
i disable speed step and turbo, change cpu from auto to x39 but yet it stay on x37.
what im doing wrong?
i mean as u said i cant do more "complex" oc, but i should be able to set those core to x39 always, and no matter what setting i do its stick to x37
HenryW
« Reply #5 on: 26-April-19, 12:02:55 »
Core ratio limit 1-2 cores 39, 3 cores 38, 4 cores 37. So max speed you will get on 4 cores is 3700 or a little less on that board. With your particular CPU it's slightly less.
Corsair TX650W
