Author Topic: Is the MSI Trident 3 Graphic 1060 3Gb upgradable to... anything better?  (Read 568 times)
FredzouilleTopic starter
For a few VR games, no one will disagree that the 1060 3gb can be a bit slow... I'm on DCS and Elite dangerous for the record ( they work but,... you don't get all of it).
Most other games I tried work fine to be honest.
Right, so I read so many things... let's bring the thread again.
Power, motherboard issues, pins, adaptors, cables fix,...
Am I stuck with that GTX 1060 3Gb???
What about the new RTX series?
Trident 3
i7-7700
8Gb Ram ( upgrading soon to 32Gb some flightsim can eat that much)
Nvidia 1060 3Gb
Thanks for your advice folks!
Yang
  • AIO Moderator
MSI has 7 models for Trident-3 but all are different.
Please provide some information as below to us for this system you used:
1. Serial number on the back cover and on the box.
It is SOP how to check it as below link:
http://www.msi.com/page/warranty
Example: MSB9xxxxxxxxxxxx
2. The number:9S6-B9xxxx-xxx that you can find it on the box.
Thank you Yang
9s6-b90611-057
Yang
  • AIO Moderator
It is specificaiton for Trident-3 on MSI website.
GeForce® GTX 1060 Gaming 6GB/3GB GDDR5
GeForce® GTX 1050Ti 4GB DDR5
https://www.msi.com/Desktop/Trident-3/Specification
It is recommend list for Trident-3 on MSI website, please click "Recommend" first.
https://www.msi.com/Desktop/support/Trident-3
No RTX graphic is on recommend list.
