Author Topic: cant install windows 10 on a z270 carbon pro motherborad  (Read 307 times)
jtmillercoolguyTopic starter
i have (2) m.2 samsung 970 evo pro 500 gb drives,, trying raid my msi Z270 motherborad, , the bios is jan 2018, i set every thing bios to raid and i see combined 2 drives to one  ,, when installing or trying to install windows 10 , windows 10 says no drives were found, but if i change it to non raid it will see both m.2 drives when installing windows 10 on one of the drives , i also using a windows 10 dvd and downloaded a driver from intel for the raid put them on a usb drive but it wont let me install the driver so i can not see the raided hard drives ,, i have been trying to install windows 10 for 3 days no luck,, i dont know how to get the windows 10 to see the drive,, i see other peaple and other forums having the same problem,, probally no fix for this problem or too compicated
pandaz
  • MAJOR
Which windows 10 version are you using? is it windows 10 RS5?
Also which RAID driver did you use for loading during wind 10 installation?
