Author Topic: Boot Stuck Error 92  (Read 524 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
wizardblueTopic starter
Boot Stuck Error 92
« on: 06-May-19, 05:50:16 »
My motherboard: MSI A78M-E35 (MS-7721) Military Class 4
Chipset AMD A10-7700K Radeon R7, 10 Compute Cores 4C+6G
Bios Version v 30.6 (up to date)
Windows 7 Ultimate 64Bit
I saw that on the forum my problem has already been dealt with, but although I tried the various solutions I didn't solve, I explained:
at the first start of the pc (after turning it off the night before), the boot crashes on the error 92, when it is inserted (in any usb, you already try all),
my wireless pen model D-Link AirPlus g DWL-122 (have 12 years old).
If i remove it goes immediately, putting, it goes 1 minute, it starts everything, but the pen remains as off on windows, as if the motherboard blocks it, so both in the start and after I am always forced to disconnect the wireless pen every time, a great nuisance.
As I have already written tried with all the usb, but nothing equal. Made cmos, nothing buffer removed.
Finally strange thing, after I start it I remove the pen, the PC loads normally, I insert it with the Windows on I turn it on, everything is ok. Reboot and so the boot doesn't freeze !!!
Sorry for my bad english iìm Italian user, i hope you understand
[/pre]
rbleroy91
  • GENERAL
  • RBL_FR
Re: Boot Stuck Error 92
« Reply #1 on: 07-May-19, 17:42:25 »
Yes, it is old and is even End of Life (since october 2007)! :biggthumbsdown:
Perhaps, updating its firmware should resolve: go to >>D-Link | Technical Support<< and select DWL+G122. Last firmware was published at june 2014.
Hoping it shall help,
:hat tip:
« Reply #2 on: 08-May-19, 07:00:36 »
Hello, thanks for reply.
The driver not compatible with my D-Link product :undecided:
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #3 on: 08-May-19, 07:50:29 »
Do not click on the first row who deals with the drivers but the next ones for Firmware:
Unfortunately, if that did not work, I believe your WiFi adapter is too old beeing EOF since october 2007! :undecided:
Have a good day,
:hat tip:
« Reply #4 on: 08-May-19, 13:46:31 »
Thanks, I had the wrong firmware I had taken the one of the dwl extreme, now I have installed those posted by you, tomorrow at the first start I will see if it starts everything.
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #5 on: 08-May-19, 17:01:14 »
Tomorrow at the first start I will see if it starts everything.
Thank to let me known.
Good luck!
:hat tip:
« Reply #6 on: 09-May-19, 02:19:56 »
Hello, nothing to do the problem remains :undecided:  Patience when i do i take a pci lan or another wireless pen. For now i will continue attack and disconnect mine the pen for the dock.
I just hopeit does not spoil :undecided:
Marked as best answer by wizardblue on 09-May-19, 16:31:46
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #7 on: 09-May-19, 02:58:46 »
Nothing to do the problem remains :undecided: Patience when i do i take a pci lan or another wireless pen.
:cry:  Right, I think it is time to buy a new WiFi adapter because your 12 years old adapter is now obsolete.
Really sorry for this bad news,
:hat tip:
« Reply #8 on: 09-May-19, 15:33:52 »
Thanks for all next time :biggthumbsup:
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #9 on: 09-May-19, 16:10:55 »
You are :welcome:
Friendly yours,
:hat tip:
