Author Topic: Overclocking options missing in UEFI - P67A-GD65  (Read 536 times)
coendelengTopic starter
So i've recently upgraded the GPU in my gaming desktop from a GTX 970 to a GTX 1070ti.
Utilising the GTX 1070ti to it's full potential, I figured I should try to overclock my CPU (i7-2700k).
The problem is that the overclocking options seem to be missing in my motherboard's UEFI.
Under the setting CPU features in the overclocking menu, the 4 core's radio limits are missing.
I also can't seem to increase the CPU frequency multiplier above its stock value (3900Mhz).
What are my options? Can I try to flash an older UEFI version? Im currently running the newest software available (4.3)
Also worth mentioning: on my Windows 10 installation, the driver named Intel Management Engine seems to be missing.
When trying to install the newest version it gives an error message.
Board: MSI P67A-GD65 (non B3 version)
BIOS: V4.3
VGA:   MSI GTX 1070 Ti Armor 8G
PSU:  Cooler Master G550M
CPU:  Intel® Core™ i7-2700K Processor
MEM: 2x8GB, 1866MHz Kingston HyperX Fury red HX318C10FRK2/16
HDD/SSD: Sandisk 128GB, Crucial MX500 500GB, Western Digital Black 1TB 7200 RPM
COOLER: Cooler Master Hyper T4
OC:  None
OS: Windows 10 64bit Education
dude77
  • CORPORAL
Re: Overclocking options missing in UEFI - P67A-GD65
« Reply #1 on: 21-May-19, 09:52:38 »
move to the cpu ratio press + or - to change it. it does not enlight but it should change anyway.
sorry im out of home and cannot check my bios version
if you are missing some options try a full bios clear (unplug the power from the psu and press the reset button for a few second).
good luck
Marked as best answer by coendeleng on 05-June-19, 09:15:42
  • 微星科技
« Reply #2 on: 21-May-19, 12:02:46 »
Overclocking issues are to be expected when using a Sandy Bridge cpu on an Intel 6 series board with an ME8 bios. You can also not try an older bios as an ME8 bios is required to be able to use the GTX 1070 Ti.
Windows 10 Pro
MSI MAG BUNKER Case
HenryW
« Reply #3 on: 22-May-19, 13:04:19 »
Yup to OC with the later BIOS you would need Ivy Bridge CPU.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
« Reply #4 on: 05-June-19, 08:30:05 »
Sorry, I kind of forgot about this topic existing..
That makes a lot of sense Flobelix.
So I guess my different components don't go well together to make overclocking possible.
In that case I can forget about overclocking.
Final option would be to replace the CPU with a newer generation.
Or just to replace the mobo and the CPU all together.
Anyway, I appreciate the help!
  • 微星科技
« Reply #5 on: 07-June-19, 12:32:30 »
It makes no sense to replace the i7-2700K with an Ivy Bridge cpu. It is money wasted. There will be no real performance benefit anyway. To add the P67 board not even supports PCI-E 3.0 what the Ivy Bridge cpu could add on a Z68 (G3) or Z77 board. Use the system like it is until you can afford a complete upgrade
Windows 10 Pro
MSI MAG BUNKER Case
