Author Topic: Freezes & BSODs with Trident Z RGB 4266 4x  (Read 733 times)
petrdzbTopic starter
« on: 06-May-19, 21:20:14 »
Hello!
I'm having issues with my Trident Z RGB 4266 4x8 (F4-4266C17Q-32GTZR) when I turn on the XMP profile in BIOS. Memtest fails.
Is there any idea on how to fix it?
Case: NZXT H700i
CPU: Core i9-9900k
CPU cooling: Corsair H150i
RAM: Gskill Trident Z RGB 4266 mhz (4x8gb)
MB: MSI Meg Z390 Godlike
PSU: Corsair AX 1000
SSD: M.2 Samsung 970 Evo plus 250gb (nvme, OS)
M.2 Samsung 970 Evo plus 1TB (nvme)
SHDD: 2x2tb Seagate Firecuda
GPU: MSI Gaming X Trio RTX 2080
OS: Win10 Pro
I would really appreciate any guide on how to fix the issue.
Please let me know if any info is missing.
Case: NZXT H700i
CPU: Core i9-9900k
SSD: M.2 Samsung 970 Evo plus 250gb (nvme)
OS: Win10 Pro
  • T9246ED
  • Administrator
Re: Freezes & BSODs with Trident Z RGB 4266 4x
« Reply #1 on: 07-May-19, 11:30:59 »
maybe you can try a different BIOS version
what bios version board is using?
« Reply #2 on: 09-May-19, 02:01:26 »
I'm using the latest available BIOS version (MSI website, 1.60)
is there any way I can check the proper (working version of BIOS for this set of memory?)
Probably there are some setting that I need to tweak, can anyone help on this please?
Case: NZXT H700i
CPU: Core i9-9900k
OS: Win10 Pro
  • T9246ED
  • Administrator
« Reply #3 on: 09-May-19, 08:14:14 »
try run it manually at XMPs speed, (or try "memory try it" )
btw what speed is that when you got errors after enable XMP?
« Reply #4 on: 10-May-19, 01:13:20 »
Well, please check how I do it manually:
I set DDR Speed to 4266Mhz, DRAM voltage to 1.450 & timings to 17-18-18-38 = memtest fails
When using Memory Try it = memtest fails
Now i'm running on 3866 (memory try it) - system seems to be stable, timings are the same as the XMP profile (check attachment)
What am I doing wrong?
Case: NZXT H700i
CPU: Core i9-9900k
OS: Win10 Pro
« Reply #5 on: 10-May-19, 01:25:27 »
I have also attached several files here:
1. MSINFO report
2. Aida 64 Hardware report
3. Memtest results
Maybe this could give a better view of the system & what might be wrong
Case: NZXT H700i
CPU: Core i9-9900k
OS: Win10 Pro
« Reply #6 on: 25-May-19, 05:55:01 »
Any help would be appreciated
Case: NZXT H700i
CPU: Core i9-9900k
OS: Win10 Pro
