Author Topic: No Dynamic Dashboard Lightning z 2080ti  (Read 783 times)
scottmadden356Topic starter
« on: 13-May-19, 04:20:50 »
No Dynamic Dashboard on Lightning z 2080ti..... Recently updated to Dragon Centre 1.0.0.45 the Dynamic dashboard was working fine went to customise and no longer working although dragon centre is showing it as on, all other LEDs are lit on the card. Done a fresh install of windows and dragon centre and the dynamic dashboard is still dead. Any help would be appreciated. Thanks
PC Specs as follows
i9 9900k
Z390 Godlike MB (dashboard & LEDS working fine)
MSI Lightning Z 2080ti
32GB Ram 3600mhz
1200w ROG PSU
Running Windows 10 64bit
  • 微星科技
Re: No Dynamic Dashboard Lightning z 2080ti
« Reply #1 on: 13-May-19, 14:59:53 »
Try uninstalling and reinstaling Dragon Center.
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 15-May-19, 08:37:39 »
already done as stated in post thank you. now on mystic light 1.0.0.14 and still dead this is my second msi lightining z 2080ti 1st one was faulty not happy at all
  • 微星科技
« Reply #3 on: 15-May-19, 14:04:22 »
Does anything else work like light effects?
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #4 on: 15-May-19, 16:50:35 »
everything  works by the dispaly
« Reply #5 on: 25-May-19, 14:20:22 »
is this card broken or what does it need returning. dynamic dashboard been off for 4 weeks now
« Reply #6 on: 16-June-19, 02:03:30 »
MSI GeForce RTX 2080 Ti Lightning Z .dynamic dashboard still not working with new dragon center 1.0.0.49 and mysticlight 1.0.0.15
F22
« Reply #7 on: 01-September-19, 01:37:17 »
In my case Dynamic Dashboard doesn't work if the card just a little warm and computer was restarted. It does not depend on any software. It's hardware issue. I replaced my Lightning Z, but on the second one is the issue same. I able to make the display work only by starting some game or other 3D app immediately once OS is loaded.
And it doesn't depend on BIOS version. The same behavior on LN2 or Original and versions are latest. Dynamic Dashboard could start work if in the room quite cold and you turn on the computer.
