Author Topic: Tomahawk B450 Heat Sink Mount Pins Broken on Arrival!  (Read 145 times)
kierandodson420Topic starter
Is there anywhere i can buy these Mount pins separately? As on arrival they seem to have been snapped during delivery, extremely upset cannot use the motherboard now until i manage to fix this problem
pandaz
  • CAPTAIN
Re: Tomahawk B450 Heat Sink Mount Pins Broken on Arrival!
« Reply #1 on: 14-May-19, 20:51:54 »
which particular mount pins broken?
if that is a new MB, maybe you could check with the seller to exchange it?
HenryW
« Reply #2 on: 14-May-19, 23:56:50 »
Is this the part you refer to? AM4 heatsink retention bracket. If so you can find at Amazon for 1 place to get it.
  >> AM4 bracket <<
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
