Author Topic: MSi GL62M-7RDX Gaming Notebook GPU OC?  (Read 190 times)
KnightsovTemplarTopic starter
« on: 15-May-19, 15:20:47 »
Hi I recently bought this gaming notebook and the Dragon Center allows you to overclock the GPU. My problem is that my GPU Core clock stays at 1354MHz even after I slide the core clock offset all the way to the right which is +150MHz. The GPU memory clock defaults at 3504MHz and there is no problem increasing the vram clock offset at 250MHz. Does anyone know how to fix this? Thank you.
