Author Topic: ms-aa5e AIO Case + Upgrade?  (Read 388 times)
sean.mohrhoffTopic starter
« on: 18-May-19, 15:19:04 »
Howdy! How limited are the shells for the MS-AA5E system, otherwise known as the Wind Top AE2051 All-In-One PC? Hopefully its a bit universal, as I managed to install an mATX board into an old DELL Dimension 2400 series case.
Are there any compatible system boards, CPU/APUs and discrete GPUs available to install?
Is the PSU replaceable if I need more wattage?
Are there water cooling systems for AIOs?
I have this unit as it came in the form of a WOW! computer system for Seniors. It belonged to my late father and it was passed to me and it still works but its a bit limited as its only 1.x GhZ and I can't increase RAM any further but I am digging as it has a Touch Sensitive screen. I swapped out the hard drive for something better and installed a light weight OS, LUBUNTU.
Thanks in advance!
Nichrome
Re: ms-aa5e AIO Case + Upgrade?
« Reply #1 on: 18-May-19, 16:00:42 »
Hi
With some modifications you might fit ITX board with some basic cooler, but I wouldn't bother with it to be fair.
Discrete GPU? Forget about it. This is an All in One, not a desktop.
