Author Topic: BIOS request for 2080ti Seahawk EK X  (Read 289 times)
alouTopic starter
« on: 21-May-19, 12:06:08 »
I'm using the bios which version is MSINV371MH.192
Could you please check for me whether there is a newer version.
S/N: 602-V371-14SB1810000124
  • 微星科技
Yes, there is an update. Latest is NV371MH.193 (attached).
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV371MH.193 to .rom (e.g. 193.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 193.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 193.rom
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
alouTopic starter
Re: BIOS request for 2080ti Seahawk EK X
« Reply #2 on: 21-May-19, 12:12:00 »
Thanks for your quick and kind reply. :kiss:
  • 微星科技
« Reply #3 on: 21-May-19, 12:12:25 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
allainpiqui
« Reply #4 on: 20-July-19, 02:54:32 »
Good Evening flobelix,
my Video Card is the same (2080 TI Seahawk ek x) but my Bios version is showing the following 90.02.17.00.2C, does the NV371MH.193 work for my card too?
  • 微星科技
« Reply #5 on: 20-July-19, 03:34:10 »
Open an own thread please. There add the S/N
:floblock:
Windows 10 Pro
MSI MAG BUNKER Case
