Author Topic: Upgrading MSI 2A9C motherboard  (Read 539 times)
prospero.spbTopic starter
« on: 23-May-19, 05:50:42 »
Good day! I need to upgrade a computer with an installed motherboard MCI 2A9S. What is the maximum configuration (CPU / RAM) possible on this motherboard? Thank you in advance
HenryW
Re: Upgrading MSI 2A9C motherboard
« Reply #1 on: 23-May-19, 08:30:45 »
That is I believe an HP computer therefore you need to go to HP for support. We don't have any support for OEM boards like that nor does MSI.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
« Reply #2 on: 23-May-19, 08:51:43 »
Thank you for quick answer
  • 微星科技
« Reply #3 on: 23-May-19, 11:13:44 »
:floblock:
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
