Author Topic: P55 CD53 continuously restarting but no del or F1 response  (Read 228 times)
kl4150rockTopic starter
I have almost the identical issue as the post "P55 CD53 continuously restarting.  It does not matter whether or not the Win 10 SSD or the Win 10 install disk are active on boot.  The splash screen appears briefly then reboots ad infinitum.  Pressing the F1 ore del key during boot makes no difference.
The PC had been running well until yesterday, when it began to have restarts and recovery.  Now, the restart never recovers.  Tried all the suggestions in the reference with no effect.
Open for ideas.
  • 微星科技
Add the full system specs: >>Posting Guide<<
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
