Author Topic: KT3 Ultra-ARU processor compatibility?  (Read 2152 times)
TamasTopic starter
  • SERGEANT
« on: 29-October-03, 10:11:30 »
This motherboard can support an Athlon XP TBred 2600+ processor as a maximum. What I'm not sure about is if it can handle one with 333 MHz FSB. I believe it can not - can someone confirm this?
It seems to be rather hard to find a 2600+ with 266 MHz FSB - all the available ones seem to be the 333 MHz version. I guess I cannot use that one on this board  :undecided:
Thanks for the help.
KT3 Ultra-ARU (BIOS 5.5), Athlon XP 1800+, Thermaltake Volcano 9 cooler, 1 GB GeiL PC2700 RAM (2-2-5-2), ATI All-In-Wonder Radeon 8500DV, Lian-Li PC-7 case, Antec TruePower 430W power supply, (2) Maxtor 80GB 7200 RPM drives in RAID 0, Plextor 12/10/32A CD-RW (UDMA-33 mode), Pioneer DVD-500M (RPC-1 regionless firmware), NEC ND-1000 DVD writer (ND-1100 firmware), IDE ZIP 100
Ex Forum User 3
« Reply #1 on: 29-October-03, 10:50:43 »
It handles all 166FSB CPU's (not official but it does) and you need PC-2700 to let it run.
xroyal
« Reply #2 on: 29-October-03, 16:32:12 »
Best I've heard for your MB w/v5.7 bios is XP3000/333 chip running fine.  :-D)
I have plain Ultra, and 166/333 FSB no problem at all, and I use 5.6 bios and Crucial PC2100.
Good luck!
TamasTopic starter
  • SERGEANT
« Reply #3 on: 29-October-03, 19:14:34 »
Are you sure about that? So then what's the maximum speed this board can handle? According to the MSI specs, it should top out at TBred 2600+ with 133/266 FSB. Bas said it can do the TBred with 166/333 FSB. Can I go any higher than 2600+?
My understanding is that the Barton core does not work on this board, so then the fastest TBred should be the top. Is that correct?
Thanks folks.
Steve F.
  • CAPTAIN
« Reply #4 on: 29-October-03, 19:32:02 »
Sorry, but I can't help wondering why bother to post a question if you're not going to trust two very clear responses?
Lots of poeple are running 333 Bartons on this board with no problem. The only issue is that the BIOS won't recognise the CPU automatically. Bartons are "supported" on Ultra2s (w/latest BIOS) because they are recognised by the BIOS. On the KT3 Ultra-ARU, you have to set the multiplier manually. On either verion you have to set the FSB manually, so setting the multiplier as well isn't much difference.
Of course, some people have problems even with supported CPUs, so no guarantees!
MSI K8N Neo Platinum
Athlon 64 3400+ Clawhammer (stock heatsink/fan)
Enermax EG465AX-VE 431W PSU (squillions of amps on all rails)
2*512MB Kingston HyperX PC3500 (CL2.5)
MSI FX5700-TD128 (<--junk!) BFG 256MB FX5700 OC
2*WD Raptor 74GB SATA (RAID 0)
1*Maxtor DM Plus 9 80GB SATA
Plextor PX-712A DVD±R/RW
Win XP Pro SP2
Others: K8T Neo2-F + 3500 Venice, KT3 Ultra-ARU + XP 2500+
TamasTopic starter
  • SERGEANT
« Reply #5 on: 29-October-03, 21:12:30 »
Chill out man, there was no talk on my side about not trusting the responses, but rather I wasn't sure if I understand everything correctly. Are you always so uptight? :rolleyes_anim:
I merely want to make sure that I don't buy a CPU that I won't be able to use. I read the OFFICIAL specifications for my board that are coming from MSI and that's what made me unsure.
Thanks for the answers. :biggthumbsup:
Steve F.
  • CAPTAIN
« Reply #6 on: 29-October-03, 21:43:01 »
I'm chilled.  ;-))
Win XP Pro SP2
xroyal
« Reply #7 on: 30-October-03, 03:15:25 »
Here's the rig I was talking about above.
http://www.amdforums.com/showindex.php?s=281e736dc399e513305db834ff8ba7a8&threadid=261598
Can't blame you for wanting to be safe. Good luck!  :smile:
