Author Topic: Finish upgrade to Win 10 Pro but it return to Win 10 Home after clean install  (Read 655 times)
nai_yaiTopic starter
Hi all
I own MSI GS75 8SF coming with Windows 10 Home
I purchased Windows 10 Pro license and already upgrade it to Pro. I also already Activate Win 10 Pro. It works well.
But.... but.. but...
I do a clean install Windows 10 again with a latest image download from Microsoft website.
After clean install. My OS return to Windows 10 home ! ! ! !
Why???
Does anybody help me? Let me know, how can I do a clean install and I get Windows 10 Pro
shaneggpierce
Hi all
Why???
Facing the same issue here too. Help is highly appreciated.
Thanks in advance,
Regards,
Shane
jeffmarsden
jeffmarsden
Found a work around - but not ideal for Windows 10 Home to Pro
  • Unplug/Turn Off internet connection
  • Enter the following generic Windows 10 Pro key
  • VK7JG-NPHTM-C97JM-9MPGT-3V66T
  • system should then upgrade to Pro
  • after reboots etc..  Turn on / Plug in Internet connection
  • Change product key to your offical new product code
Good luck
sunscreen
  • FIRST LIEUTENANT
Windows 10, both home and pro should keep the Windows key in the firmware so that after any update, upgrade or fresh install the Windows key is there and you get the Windows that you paid for.
Unfortunately many people still have problems such as bought Pro but it resets to Home.
https://answers.microsoft.com/en-us/windows/forum/windows_10-update-winpc/restore-from-windows-10-pro-to-genuine-windows-10/bba4c118-847f-476c-94eb-184184a778e6
https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/windows-10-pro-reverts-back-to-windows-10-home/266cc755-aed4-4bca-9a8d-330e2be36765
I suggest that when you install Windows, keep a copy of the Windows key in a safe place away from the computer.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
Hi all
Why???
Windows registers to the hardware on your system, it stays that way unless you enter the Pro key during the clean install process.
In Canada Call MSI @ 1-888-447-6564
Mon-Fri 5:00AM-4:00AM PST (Weekend and Holiday closed)
Note: RMA, Customer Service, Technical Support
Global 1-800 listings https://www.msi.com/page/hot-line
