Author Topic: One color back light keyboard only on this model?  (Read 313 times)
GoobTopic starter
Hi there,
I'm not a big tech person but here i am with a MSI based on recommendation from a friend. I have the GV62 8RD and the keyboard back light color is red and red only. I can't figure out how to change it for this model. Im beginning to think that black Friday sale won me a kind of janky one. IDK but i tried installing the steel series engine 3 but it doesn't pick up the keyboard or like recognize it idk. Is it possible to change the keyboard back light on this model or no?
sunscreen
  • FIRST LIEUTENANT
Re: One color back light keyboard only on this model?
« Reply #1 on: 11-June-19, 18:46:02 »
Before buying a laptop it is a good idea to check the specifications and consider your need before buying.
https://www.msi.com/Laptop/GV62-8RD/Specification
shows Backlight Keyboard (Single-Color, Red)
Caveat emptor - Buyer beware or check before your buy
GoobTopic starter
« Reply #2 on: 11-June-19, 23:54:06 »
Thanks for the reply. My friend looked at the specs but ok. Red will have to do thank you.
