Author Topic: Please help need to make my MSI Lightning 680 UEFI GOP Win10 compatible  (Read 262 times)
jquanTopic starter
I read all possible threads.
Tried nvflash with file NV283MH.102
but there is a PCI ID discrepancy and it does not flash
THIS is my GPU
10DE-1180-1462-2833
and the NV283MH.102 expects only 1462 2830 <<<<
a backup of my vBios is in Ticket#425291 <<<<<< and here if it works
Many thanks
  • 微星科技
Your S/N is needed to check:
Windows 10 Pro
MSI MAG BUNKER Case
jquanTopic starter
If feasible with the dual switch
I dream to keep my existing BIOS (for use of the GPU in older Mobo), then on other ROM install a UEFI GoP Win10 ready ROM
Here is my S/N
602-V283-04SB1208071267
Many thanks for your help
  • 微星科技
NV283MH.102 is the latest normal UEFI vbios for your card and NV283MH.112 is the latest LN2 UEFI vbios.
Get them here: https://forum-en.msi.com/index.php?topic=281618.msg1597103#msg1597103
Windows 10 Pro
MSI MAG BUNKER Case
jquanTopic starter
I am afraid you might have replied too fast.
A.  This is what ahppens when using that thread
THIS is my GPU
10DE-1180-1462-2833
B. Also please review Ticket#425291 inside there they hint towards NV283MS <<< instead of NV283MH
Any hope to get the right UEFI rom files?
  • T9246ED
  • Administrator
that's not possible, its user forum,
we do not work for msi and we can't access your official tickets.
files that Flobelix linked are correct.
THIS is my GPU
10DE-1180-1462-2833
That's fine, the sub-id will change legacy != GOP
just add "-6" parameter when flashing the vbios
etc:
nvflash64 your.rom -6 [ENTER]
and confirm with "Y" to override for any propmts
