Author Topic: rx590 mod for 26 qe model  (Read 288 times)
whizkid1331Topic starter
« on: 14-June-19, 17:19:28 »
Hey, everyone, I own a 26qe MSI AIO and my cousin asked me to tell me a GPU which can upgrade and yield some life out of the 26qe, how can i Pair the gpu with the AIO and im looking for a GPU from these options https://appuals.com/best-rx-590/ please let me know which one should I get?
sunscreen
  • FIRST LIEUTENANT
Re: rx590 mod for 26 qe model
« Reply #1 on: 14-June-19, 17:57:45 »
I could not find your 26qe MSI AIO, but plenty of 24T 6QE.
Open the machine and check on the spare sockets, also look at the specifications for your machine, how much power is available for PCIe sockets.
What graphics card is it using now?  Some have Nvidia GTX 960 which is a reasonable card.
Don't buy something that requires more power than yours provides.
If you still have questions, consider contacting MSI support for advice.
  • 微星科技
« Reply #2 on: 15-June-19, 10:12:07 »
Clarify what pc you have. So far there is no MSI product to be identified.
Windows 10 Pro
MSI MAG BUNKER Case
