Author Topic: MSI EX 610 /163d on w7  (Read 199 times)
savicsvetolikTopic starter
« on: 18-June-19, 16:30:49 »
Q. can my MSI EX 610 /163d  work on w7/64
sunscreen
  • FIRST LIEUTENANT
Re: MSI EX 610 /163d on w7
« Reply #1 on: 18-June-19, 19:12:36 »
Short answer: Yes, it can.
Longer answer:  https://www.msi.com/Laptop/EX610/Specification
shows that it has AMD® Turion 64x2
the '64' is the give away that this is a 64 bit processor, so it can run not only Win 7 64 bit, but much better Win 10 64 bit.  Win 7 end of life is January 2020.  Why install an OS that only has 6 months support?  Better to install Win 10 with support until the machine dies.  You can also install other 64 bit OS, such as BSD, GNU / Linux.
If interested you can go to amd.com and search for your processor then download the specifications.
https://www.amd.com/en/support/tech-docs/amd-turion-64-x2-mobile-technology-dual-core-processor-product-data-sheet
