Author Topic: GF63-8RD compatible with a eGpu?  (Read 323 times)
inventorjmTopic starter
« on: 24-June-19, 05:29:30 »
Hello
I have this notebook with the 1050ti. I was wondering if it supports an external gpu in the wifi port (mPCIe if I'm not wrong)
Thank you!
freeyh
  • CAPTAIN
Re: GF63-8RD compatible with a eGpu?
« Reply #1 on: 24-June-19, 05:45:04 »
It's not a common way to support for eGPU with using the WiFi card module connection slots.
And the layout of the laptop's MB is different from the desktop's MB. Unless you can get the diagram, or else you won't know whether the layout for the WiFi card module connected to CPU would support for the external GPU just like Thunderbolt 3 or not.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #2 on: 24-June-19, 12:45:29 »
Hello
Thank you!
No.
In Canada Call MSI @ 1-888-447-6564
Mon-Fri 5:00AM-4:00AM PST (Weekend and Holiday closed)
Note: RMA, Customer Service, Technical Support
Global 1-800 listings https://www.msi.com/page/hot-line
« Reply #3 on: 27-June-19, 12:47:22 »
Thanks everyone
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #4 on: 27-June-19, 13:33:22 »
