Author Topic: Thunderbolt 3 controller requires constant reset  (Read 417 times)
ranronTopic starter
« on: 24-June-19, 11:33:17 »
I just got a GS75 Stealth (9SG) some two weeks ago. Excellent gaming laptop overall. The only problem is the Thunderbolt 3 controller.
When I first got it, the Thunderbolt didn't work at all and I had to re-install the drivers multiple times to get it work. Now the problem is whenever I plug in my Thunderbolt 3 device, I need to disable and re-enable the device in 'Device Manager' to get it working. It's quite annoying because I use Thunderbolt for a 10G NIC which means it's constantly being plugged in and unplugged. I do stop the device before I disconnect, but it doesn't seem to make much of difference.
Is there a solution for this or a firmware that I'm missing that addresses this issue?
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
Re: Thunderbolt 3 controller requires constant reset
« Reply #1 on: 24-June-19, 12:16:49 »
The hardware is working, it's the firmware/software that needs sorting out.
Is your BIOS and EC up to date? https://www.msi.com/Laptop/support/GS75-STEALTH-9SG
ranronTopic starter
« Reply #2 on: 24-June-19, 12:36:04 »
Is your BIOS and EC up to date? https://www.msi.com/Laptop/support/GS75-STEALTH-9SGy
Yes, I have the latest BIOS and drivers. That's the first thing I did was to ensure everything was the latest.
EDIT: It looks like I wasn't aware the EC firmware is something else entirely, I'll update it see if that fixes my issues.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #3 on: 24-June-19, 12:40:58 »
EC is very important and you must follow through with the reset procedure after installing.
ranronTopic starter
« Reply #4 on: 24-June-19, 12:50:58 »
The instructions says that after the update is completed, if I have a removable battery I need to remove it for 10 seconds to clear the EC RAM.
However it says if my battery is non-removable (it's non-remowable), the EC RAM will be cleared up the update. Am I suppose to unplug and leave it off for 10 seconds? If I the read instruction as is, there are no steps after the update for me.
EDIT: I've gone ahead and done the update. I'll report back if the issue returns or not. Thanks for your help!
RaiderGamer
  • LIEUTENANT COLONEL
« Reply #5 on: 24-June-19, 13:04:49 »
my laptop has a pinhole on the bottom that goes into a very small button to reset the ec
the pinhole is so small even a medium size paperclip wont fit in, i had to use a twist tie with the plastic stripped off, which worked because the button is so small it presses very easily
i think i can hold that down for 10 seconds to reset the ec, i did that after i updated my bios in device manager
Click Here to:    Download Windows 10     Reinstall Graphics Driver     Update Bios
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #6 on: 24-June-19, 13:14:37 »
User manual: http://download.msi.com/archive/mnu_exe/nb/17G1_v1.0_English.zip
freeyh
  • CAPTAIN
« Reply #7 on: 24-June-19, 21:42:43 »
Have you tried uninstalling the Thunderbolt driver and the control panel and fully reinstall?
To make sure the Thunderbolt 3 work normally, you need to install the correct version of the driver and control panel.
Follow this post might give you some help.
And under the control panel, you can select your TB3 device for the behavior like attached figures.
ranronTopic starter
« Reply #8 on: 25-June-19, 02:47:37 »
I did all the updates and the applicable after update procedures.
Anyways looks like I still have problems. I need to disable and re-enable the Thunderbolt device every time I plug my NIC in.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #9 on: 25-June-19, 13:25:18 »
Must be the firmware on the NIC, try a different brand?
