Author Topic: MSI GV62 8RD Network issues  (Read 522 times)
mbnevelingTopic starter
« on: 24-June-19, 13:44:48 »
My network adapter has stopped working, When i try installing drivers it says that there is no hardware. Has anyone had this issue? Its kind of important. I need the rj45 connector to work for work. Without it, this laptop is useless.
Re: MSI GV62 8RD Network issues
« Reply #2 on: 24-June-19, 14:49:31 »
This is what my device manager looks like.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #3 on: 24-June-19, 14:53:04 »
Buy a new card.
In Canada Call MSI @ 1-888-447-6564
Mon-Fri 5:00AM-4:00AM PST (Weekend and Holiday closed)
Note: RMA, Customer Service, Technical Support
Global 1-800 listings https://www.msi.com/page/hot-line
RaiderGamer
  • LIEUTENANT COLONEL
« Reply #4 on: 24-June-19, 15:52:24 »
Buy a new card.
but if its the ethernet he needs isnt that hard connected to the mobo? maybe he needs an external usb ethernet device, if they make those
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #5 on: 24-June-19, 18:47:08 »
His picture shows the killer wireless card not being detected, so ya, a new wireless card or reseat it.
RaiderGamer
« Reply #6 on: 24-June-19, 19:36:39 »
i think its his killer ethernet
my raider has killer ethernet too
i dont really like it cuz it automatically installs some process thats always running in my task manager even though i never use ethernet,
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #7 on: 24-June-19, 19:51:50 »
I would rather be on LAN than WiFi, but WiFi it is so I tossed the Killer and went with Intel, it works flawlessly with an Intel processor.
LAN is so much faster than WiFi, especially for DLing large files.
annet
  • CAPTAIN
« Reply #8 on: 25-June-19, 01:27:33 »
Anything you've done before this happened (like any updates)?
Try to update BIOS:
https://www.msi.com/Laptop/support/GV62-8RD
after that, update your EC firmware:
https://www.msi.com/Laptop/support/GV62-8RD#down-firmware
The instructions are included once you download the file.
« Reply #9 on: 25-June-19, 04:56:23 »
Thanks guys, woke up this morning and the Ethernet port decided to work again. I did nothing to it. Hopefully it doesn't happen again.
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
« Reply #10 on: 25-June-19, 13:28:02 »
Something update, most probably a MS KB went through without you knowing it.
Take a look in your update history.
