Author Topic: Screen shutter, lagg when connect to TV via HDMI  (Read 186 times)
casseiusTopic starter
  • CORPORAL
« on: 24-June-19, 19:57:54 »
GE73 Raider RGB 8RF
Whenever i connect my laptop to my Samsung 4k UHD  tv, the whole system starts to lagg, and only works fine  after i restart it, even laggs when i turn on laptop and tv the same time.
Everthing works fine with my other laptop.
Fresh and clean win 10 all drivers up to date.
freeyh
  • CAPTAIN
Re: Screen shutter, lagg when connect to TV via HDMI
« Reply #1 on: 24-June-19, 21:12:34 »
Which ports do you use to connect to the TV? HDMI or mDP?
Besides, which mode did you select for? Duplicate, Extend, or the second screen only?
Make sure you've installed the latest version drivers for both Intel and NVIDIA graphics.
And you can check under NVIDIA control panel and check the PhysX settings select the NVIDIA GPU as default.
Take a look at this post might help you.
RaiderGamer
  • MAJOR
« Reply #2 on: 24-June-19, 22:20:11 »
i have same laptop, GE73 Raider RGB 8RF
mine is working fine with hdmi and mdp simultaneously
no lag
  • CORPORAL
« Reply #3 on: 26-June-19, 20:14:37 »
Using HDMI, as said all drivers up to date, tried to change the PhysX, but not working
RaiderGamer
  • MAJOR
« Reply #4 on: 26-June-19, 23:35:46 »
try windows button + P button
also try
Win+Ctrl+Shift+B
pennknig
  • LIEUTENANT COLONEL
  • Online Online
« Reply #5 on: 27-June-19, 11:21:10 »
LOL .... did you even look at the OP?
