Author Topic: Extra ventilator?  (Read 164 times)
hschulzeTopic starter
  • CORPORAL
Extra ventilator?
« on: 26-June-19, 06:56:23 »
Extra ventilator on:
MSI 990FXA-GD65 (MS-7640)
Hi, Can you install an extra ventilator on this mainboard? The components are very hot with this weater. (33 C right now)
Thank's
Nichrome
Re: Extra ventilator?
« Reply #1 on: 26-June-19, 07:42:17 »
Hi
Yes you can get any fan you want that has 3 or 4 pin connector and install it in your chassis.
E.g. https://www.corsair.com/uk/en/Categories/Products/Fans/AIR-SERIES-LED-CONFIG/p/CO-9050007-WW
  • CORPORAL
« Reply #2 on: 26-June-19, 09:23:10 »
Hi, Thank's for the quick anser.
Regards........
