Author Topic: Cant get into bio of MSI Cubi N  (Read 516 times)
marnus911Topic starter
« on: 28-June-19, 00:49:34 »
Hi
trying to get into the bios of my MSI Cubi N. Tried F8, F2, Del, But it never gets into bios.  Using USB Keyboard.
any help please.
sunscreen
  • FIRST LIEUTENANT
Re: Cant get into bio of MSI Cubi N
« Reply #1 on: 28-June-19, 04:36:26 »
If Windows fastboot is on, you may have to access BIOS the first time from within Windows.
https://www.howto-connect.com/access-uefi-bios-settings-on-windows-10-8-and-8-1/
Usually Del key works, but depending on how Windows was installed, it may not.  The above should reboot into BIOS.
