Author Topic: RTX 2080 Ventus OC bios  (Read 380 times)
mansonfamily6368Topic starter
« on: 09-July-19, 00:57:17 »
Hi, I just switch my 1070 gaming x for a 2080 ventus oc. According to gpu-z it comes with nv372mh.114 bios and live update say's it is the latest. Searching this forum I find there is a new version (nv372mh.116), but I don't know if it really is for my card.
 The reason I searching for a new bios is that : when I use g sync with an free sync monitor (LG 34UC79G) it blinks black, like something is resetting in it. Using the same monitor with 1070 card, g sync compatible mode worked fine, just needed to change back and forth refresh rate when pc wake from sleep, due to lost synchronization.
 I attached current bios extracted with gpu-z, and maybe someone can direct me to the new bios and if it's good for me.
   Thank you for your attention.
  • 微星科技
Re: RTX 2080 Ventus OC bios
« Reply #1 on: 09-July-19, 12:33:22 »
You will have to add the card's S/N
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 09-July-19, 12:46:53 »
Didn't know.
The serial number is 602-V372-33SB1810001623.
  • 微星科技
« Reply #3 on: 09-July-19, 12:58:58 »
Yes, you are using vbios version NV372MH.114 and there is an update as latest is NV372MH.116: https://forum-en.msi.com/index.php?topic=313077.msg1794627#msg1794627
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #4 on: 09-July-19, 13:04:51 »
Ok, thank you very much. I'll test and see. Have a good day.
  • 微星科技
« Reply #5 on: 09-July-19, 13:48:00 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #6 on: 20-July-19, 00:30:52 »
Hi, I have a quick question : if I flash to vbios .116 and something guess wrong or I don't like it, can I go back to .114 using the same method ?
  • 微星科技
« Reply #7 on: 20-July-19, 01:43:04 »
Yes, you could.
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #8 on: 20-July-19, 01:57:27 »
Thank You !
  • 微星科技
« Reply #9 on: 20-July-19, 02:12:35 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
