Author Topic: How to apply for motherboard RMA?  (Read 323 times)
vsnsitTopic starter
  • PRIVATE E-1
« on: 10-July-19, 12:18:35 »
I'm trying to place a request for Repair/RMA my montherboard (B450 tomahawk).
When i go to My Support in my products i see nothing helpful (see attached screenshot).
What's the correct place to apply for RMA?
darkhawk
Re: How to apply for motherboard RMA?
« Reply #1 on: 15-July-19, 16:25:29 »
Have you registered your motherboard? It doesn't appear like you did.
Honestly, I usually just call them. I hate filling out the online forms and such. But that's just me. See : >>How to contact MSI.<<
kayla.duggan
  • PRIVATE E-1
« Reply #2 on: 28-July-19, 22:01:28 »
register your motherboard the easiest way is to go into bios if you don't have anything with a serial number on that's what i did because i just found it more convienient then after that you should see request for a rma show up at the bottom of the page.
