Author Topic: Mystic light 3 error  (Read 453 times)
villsterthemillsterTopic starter
« on: 14-July-19, 04:59:47 »
Hello everyone,
I am currently having trouble with the MSI Mystic Light application.
Whenever i try to open it it says "this platform does not support this application"
I want to use it for my inwin 303 MSI Dragon edition
 I am using a Asus Prime x470 Pro and a ASrock phantom rx 570 graphics card.
Does anyone have a fix for this?
Thanks,
Emiel
  • 微星科技
Re: Mystic light 3 error
« Reply #1 on: 14-July-19, 08:04:05 »
:lol_anim: Unbelievable... You don't have a single MSI component... Of course Mystic Light is not compatible.
Buy an MSI mainboard then you can control the LEDs in your InWin case with Mystic Light.
Windows 10 Pro
MSI MAG BUNKER Case
