Author Topic: B350 pc mate  (Read 903 times)
RazhelXTopic starter
  • CORPORAL
B350 pc mate
« on: 14-July-19, 13:28:37 »
Hello all.
I've buy a B350 Pc Mate Motherboard with a Ryzen 1600.
My problem is that I buy some ram 3200Mhz Corsair Vengeance LPX C16 2x8 but the pc turns on but do not boot i just send back this ram if i take the 2400Mhz C16 2x8 will it work or not??
It's my first build so the MB have not MAJ this why i ask this question i see a bunch of guys on youtube have 3200Mhz RAM and boot at the fisrt try so...
The Ryzen 5 1600 have a speed limit to 2667Mhz my motherboard says the speed limit it's 2400Mhz or higther with the OC.
When i buy my RAM i thought it was good because on the MSI support this RAM is compatible so but when i tried on my pc it turns on but not boot the EZDEBUG LED stay on the Boot so i hope anyone here know if i buy the 2400Mhz RAM will be good for this combo.
My config is;
CPU; Ryzen 1600
MB. B350 Pc Mate
PSU; Seasonic 550w focus +
GPU; RX  580 Sapphire pulse
Thank you. =)
PS; Sorry for not putting it in the right category. =)
  • CORPORAL
Re: B350 pc mate
« Reply #1 on: 15-July-19, 09:19:36 »
43 peoples see this thread but no one one can give me an answer. Sad
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #2 on: 15-July-19, 18:08:33 »
best pickup some that are in QVL for your board and for your CPU from:
https://www.msi.com/Motherboard/support/B350-PC-MATE#support-mem-12
  • CORPORAL
Re: B350 pc mate
« Reply #3 on: 16-July-19, 06:23:19 »
Thank you for your answer.
I did that first but he didn't boot.
So i'll take some RAM at 2400Mhz (CMK16GX4M2A2400C16) and see what happen
This RAM are on the qvl and it's optimized for ryzen 1* generation. so... Wait and see. =)
  • CORPORAL
Re: B350 pc mate
« Reply #4 on: 18-July-19, 08:18:23 »
Hello.
Sadly i come back =(
I've tried with the new RAM and always nothing on the screen i tested every technique that i've but nothing.
tested 1 RAM on each slots nothing Reset CMOS nothing Just try to boot with only CPU RAM and GPU nothing Changing my HDD for a new SSD nothing Verified my cables nothing
The only thing that i can tell it's he pissed me off now i buy a good pc but nothing work why.
So when i turn on the pc, on my fractal design focus g white the led of the storage stay on until the motherboard checks the gpu then the light goes out.
Honestly i don't know what to do now.
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #5 on: 18-July-19, 08:20:06 »
take out the mainboard out of PC case
and try to boot with barabone setup with board placed over wooden table or cardbox
then try to boot
make sure to connect all power cables correctly
  • CORPORAL
Re: B350 pc mate
« Reply #6 on: 18-July-19, 08:39:34 »
I do that too.
I tried first on my case then on my table and nothing happen i tried everything that all people say to try but nothing.
It's really sad.
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #7 on: 20-July-19, 09:03:47 »
What does EZ-DEBUG shows?
Have you checked mainboard socket for any bented pins with magni-glass?
  • CORPORAL
Re: B350 pc mate
« Reply #8 on: 20-July-19, 13:37:22 »
The EZ-DEBUG shows BOOT.
I do that too and i've nothing bented or something else.
I'll buy a another motherboard next week and see what hapens and if it's my b350 pc mate the problem i'll send back for the warranty.
But i don't understand why!! All my component are new just the motherboard i bought it the last year.
On PC Part Picker a guy says i've a bad luck on this motherboard and i think it's true. =(
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #9 on: 22-July-19, 07:14:51 »
this means to me a successfully post
but unable to boot OS.
if you don't see any screen:
can you check the monitor cable?
and where is connected and how exactly?
display output too? [make sure correct output is selected from monitor/TV]
  • CORPORAL
Re: B350 pc mate
« Reply #10 on: 22-July-19, 16:52:24 »
I tried on three monitors and nothing happens.
The HDMI cable are connected to my Graphic Card.
I've check the display output too twice on each monitors
At the end of this week i'll buy my new motherboard and a speaker :) and see how much beep i've like that i'll able to find the problem.
Chike
  • GENERAL
Re: B350 pc mate
« Reply #11 on: 22-July-19, 17:17:38 »
8-pin power cable connected to the graphic card?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #12 on: 22-July-19, 17:19:28 »
also can you try a different card?
[sapphire sometimes are picky,  +  i suspect the output port of the card can make some issue]
or try a different port instead, like DVI
  • CORPORAL
Re: B350 pc mate
« Reply #13 on: 22-July-19, 18:14:47 »
Chike;
Yes
Svet;
I didn't try with a DVI cable because i don't have one but i can buy a new one and see what happens.
But if i lose again money it will :censored: me off. :)
  • T9246ED
  • Administrator
Re: B350 pc mate
« Reply #14 on: 23-July-19, 13:57:47 »
you can borrow from a friends to try
or to bring the PC to your local re-seller to test it with other parts
  • CORPORAL
Re: B350 pc mate
« Reply #15 on: 23-July-19, 15:44:53 »
I don't have any friends at the moment all my friends are in vacation. :)
In my country i don't have any re-seller i live in a small village now.
Edit; I've two choice buy a new MB and see what happens or waiting a long long time. :)
When you live in a small village it's hard to have any re-seller or friends with a pc it's the problem. It's very simple you do not have several possibilities either you buy again or you wait hoping that you find something that could help you to check your problems.
Chike
  • GENERAL
Re: B350 pc mate
« Reply #16 on: 23-July-19, 17:17:27 »
It's just a cable it is not very expensive, around $10-$15.
But does your have a DVI input?
Another option is a HDMI female to DVI male adapter, which are even cheaper but not often reliable.
CPU: i5-4670k
  • CORPORAL
Re: B350 pc mate
« Reply #17 on: 24-July-19, 05:44:16 »
I know that. =)
Yes.
cholewap
Re: B350 pc mate
« Reply #18 on: 25-July-19, 00:00:47 »
This motherboard has diodes that light up and inform which component is something wrong. Check in the user's manual what they mean. Maybe it will help.
  • CORPORAL
Re: B350 pc mate
« Reply #19 on: 25-July-19, 05:59:34 »
Pal
do you really think I would have come here without a minimum of information about how my motherboard works?? =)
[/pre]
I look what meant this led but it does not advance anything at all for now. =)
I look at everything and everything works perfectly but he doesnt boot at all so...
  • CORPORAL
Re: B350 pc mate
« Reply #20 on: 02-August-19, 05:28:57 »
Hello. =)
I'm back with a very good news.
My PC BOOT =) i changed my MB by a gaming plus by MSI and everything works very well i'm so happy because it's my first build.
Now need to download every drivers and we go to play some games. =)
Thank you fam for the help.
So bye guys and have good day.
