Author Topic: Precision Boost Overdrive MSI X470 Gaming Plus Works  (Read 2150 times)
gerardfraserTopic starter
  • SERGEANT
So I was wondering how much over max boost can you get on a Ryzen 3xxx CPU and did AMD LIE lol.
Motherboard MSI X470 Gaming Plus + 3600X
Max over boost on 6 of 12 cores is 125Mhz for total of 4525Mhz.I say Great MSI Motherboard.
Anyone have any luck going over max boost clock.
CPU
Ryzen 9 3950X -4700 Max Boost
Ryzen 9 3900X -4600 Max Boost
Ryzen 7 3800X -4500 Max Boost
Ryzen 7 3700X -4400 Max Boost
Ryzen 5 3600X -4400 Max Boost
Ryzen 5 3600 -4
Video Max boost Working200 Max Boost
https://www.youtube.com/watch?time_continue=1&v=vzp456BNG70
Pheelix
    • Builds.gg/pheelix
Re: Precision Boost Overdrive MSI X470 Gaming Plus Works
« Reply #1 on: 14-July-19, 22:04:40 »
Could you list your bios settings please, I have same board and cpu.   I have only hit 4.4ghz PBO.  Other then the voltage issue with iCue and other monitoring software.  My Vcore will stay at around 1.4-1.48 if i leave it stock lol.
:: My Builds ::
  • SERGEANT
« Reply #2 on: 14-July-19, 22:41:43 »
Sure no problem at all.You have to test which one is best for you.
Try them all out under advanced CPU configuration.There is a lot of choices to try.
Then under Digital power LCC2 for CPU/NB
Voltages are high with the CPU's .There are a couple different ways to overclock and bring temperatures in check but you have to be realistic .
BIOS Overclocking and Ryzen Master. Ryzen Master has various profiles you can save /PBO Overdrivew/Auto Overclocking/Manual can obtain lower temperatures more easily than thru BIOS.
Ryzen Master manual overclock with all timings,voltages and 3 hours or so of testing
Memory overclock-2100=4200Mhz Fabric Overclock- 1900=3800Mhz All core overclock 4300Mhz
https://www.youtube.com/watch?v=_eE6l80_Rok&t=0s
Pheelix
    • Builds.gg/pheelix
« Reply #3 on: 16-July-19, 14:19:53 »
Nice, I did manage to get 4.5 using ryzen master auto overclock.  Was just playing around with it and notice it hit 4.5.  I did try turning on the Enhanced 4, but when i checked my voltage in bios it said 1.504v  so I turned it off lol.  I didn't turn on LLC, but i will play around with it some more.
:: My Builds ::
  • SERGEANT
« Reply #4 on: 30-July-19, 11:51:24 »
Well I did not find where I could edit the first post,anyway just posting to let people know that PBO Override works and may not be for everyone until AMD get there BIOS correct.
Here is how I can run my 3600X for PBO override to work.
AMD ComboPI1.0.0.3  With Enhanced Mode 4 Set in BIOS. I am Still using Beta BIOS and not the new BIOS with ComboPI1.0.0.3ab
Can work with these Chipset drivers as follows
AMD_Chipset_Drivers_v1.07.07.0725-Release Day  -July 7 2019 with AMD Ryzen™ Power Saver Plan
AMD_Chipset_Drivers_v1.07.26.0551-Beta Drivers  -July 25 2019 With AMD Ryzen™ Power Saver Plan which does not come with this chip set ,so here is a copy for anyone who wants this power plan.
Google drive AMD Ryzen™ Power Saver Plan and How to import power plan from desktop.
Open Command Prompt as(Admin)               -powercfg -import “Full path of .pow file”
So from desktop command will look like       -powercfg -import "C:\Users\YourName\AMD Ryzen™ Power Saver.pow"
https://drive.google.com/file/d/1nXzg4CgLUoA-141QiQ0TdKL3WZ01putS/view?usp=sharing
Video 3600X Hitting 4500Mhz Cinebench20
