Author Topic: Request Latest-Correct Bios for MSI Geforce GTX 1070 Ti Aero 8G  (Read 344 times)
sokiaokiTopic starter
Iam having problem with my vga MSI Geforce GTX 1070 Ti Aero 8G , S/N 602-V330-550B1 , the gpuz reports 0gb RAM and the card not working! I use the IGP to see the MSI card, please attach the latest bios or help me fix it. I was reading some problem with micron rams, how to check if this card if affected by this?
  • 微星科技
The latest originial vbios for your card is NV330MH.301. It is attached.
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV330MH.301 to .rom (e.g. 301.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 301.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 301.rom
Windows 10 Pro
MSI MAG BUNKER Case
Thanks for your help and your quick reply! Will post back with the results!
  • 微星科技
Windows 10 Pro
MSI MAG BUNKER Case
Still nothing. The VGA never worked out of the box and the website I bought is no working anymore. What is the warranty return policy in europe?
  • T9246ED
  • Administrator
you have to return it to the place of purchase
