Author Topic: BIOS bitting after being flashed, and then not booting after the first time.  (Read 521 times)
saitchisonTopic starter
[font="Times New Roman", serif]My machine has an MSI 7529 (G31M3-L V2, as far as I know it is the "L" motherboard and not the "F" one) motherboard, and I am running Win 7.[/font]
[font="Times New Roman", serif]The BIOS is the 2.60 version of AMIBIOS8.
[/font]
[font="Times New Roman", serif] [/font]
[font="Times New Roman", serif]I was getting an endless succession of crashes and BSOD's, and after trying a number of "things" I decided to update the BIOS by flashing it with the latest version.[/font]
[font="Times New Roman", serif]I backed the BIOS up to a ROM file before doing anything.[/font]
[font="Times New Roman", serif]I downloaded the prescribed BIOS update software and BIOS ROM file from MSI, and went ahead.  The flashing processing - done from a USB flash drive formatted by Rufus with FreeDOS - went successfully.[/font]
[font="Times New Roman", serif]I started the machine, got the MSI splash screen, and then messages to say that the BIOS was not set correctly, and take F1 to enter setup, or F2 to load defaults, and so on.[/font]
[font="Times New Roman", serif]I took F2, and the machine went ahead and booted into Win 7, and I then worked with Win 7 with no problem, and no crashes.[/font]
[font="Times New Roman", serif]I shut the machine off, and when I went to reboot, all I got was a blank screen.  As far as I can see the BIOS did not even reach POST stage.[/font]
[font="Times New Roman", serif]I removed both the power cable and the BOS battery, gave it a few minutes, put the power cable and battery back in place, and then rebooted.[/font]
[font="Times New Roman", serif]Again I got the BIOS not set correctly and F1/F2 messages, and again I took F2, and again the machine booted into Win 7[/font][font="Times New Roman", serif], and again when I shut down the machine and restarted,  the BIOS would not boot.[/font]
[font="Times New Roman", serif]I then did the same reset, but took F1, and after this the BIOS would not respond.  It only seems to respond if I take F2.[/font]
[font="Times New Roman", serif]I also get exactly the same result whether I am booting into DOS from the USB flash drive, or booting into Win 7 from an HDD, so I would assume from this that it is not the drives that are the problem.  The keyboard and mouse are both PS2.  There is also a CD ROM drive that I disconnected.[/font]
[font="Times New Roman", serif]The issue does not seem to be with the general BIOS settings such as boot sequence and so on, as on the second restart after the reset the BIOS does not seem to reach the stage of actually going into the setup menu.[/font]
[font="Times New Roman", serif]I also tried getting into the "hidden" options in the BIOS using Alt E1, and CTRL F1. and Shift E1, but nothing happened see https://www.techwalla.com/articles/how-to-unlock-the-ami-hidden-bios-settings).[/font]
[font="Times New Roman", serif]I then re-flashed using the backed up version of the BIOS which I had.  This reset flashing worked successfully, and the machine booted into Win 7, but again I got my succession of crashes and BSOD's.[/font]
[font="Times New Roman", serif]There is clearly some sort of problem here with either BIOS or the hardware, and if anyone has any suggestions I would welcome them.[/font]
[font="Times New Roman", serif]I also want to unlock the "hidden" BIOS options, as it is possible that one of these may give me access to a setting will solve the problem.[/font]
[font="Times New Roman", serif]How do I actually unlock the BIOS, as the method I picked up off the web site I have given above do not appear to work?[/font]
[font="Times New Roman", serif]Stuart Aitchison[/font]
  • T9246ED
  • Administrator
can you please remove the text formatting,
currently its unreadable
Well, I certainly did not expect that!!  Let's try this again:
Again I got the BIOS not set correctly and F1/F2 messages, and again I took F2, and again the machine booted into Win 7, and again the BIOS would not boot on restart.
Stuart Aitchison
In the interests of readability it occurs to me that, if possible, an obliging moderator could possibly clear the first post.
Thanks,  Stuart Aitchison.
