Author Topic: X79A-GD45 HD audio device can't start  (Read 266 times)
flimflamTopic starter
« on: 16-July-19, 15:18:52 »
I have an X79A-GD45 motherboard that I have been using with Windows 7, I recently installed Windows 10 on the system but the 3.5mm speaker and headphone jacks produce no sound.
Windows 10 device manager is reporting "Code 10: Device cannot start" for an HD audio device, presumably this is the problem. I re-installed Windows 7 again, audio works fine. Re-installed Windows 10 after that and still see a Code 10 on the HD audio device. I have tried uninstalling the device and drivers so they get reinstalled to no avail. I cannot update the drivers any further as Windows says it already has the the most recent drivers and I am running the latest BIOS
Presumably there is some incompatibility with Windows 10 as audio works fine on Windows 7. Anyone have any ideas?
  • T9246ED
  • Administrator
Re: X79A-GD45 HD audio device can't start
« Reply #1 on: 16-July-19, 15:24:44 »
can you list detailed system specs, see>>Posting Guide<<
« Reply #2 on: 17-July-19, 19:28:36 »
Sure:
Board: X79A-GD45
BIOS: 2.8
VGA: GTX 1060
CPU: i7 i7-3930K
MEM: 2x8GB DDR3-1333
COOLER: 120MM tower
SSD: 512G Samsung
PSU: 750W Corsair
I can get the specific part numbers for the memory, PSU etc if that's truly needed here.
  • T9246ED
  • Administrator
« Reply #3 on: 20-July-19, 09:48:28 »
have you tried to install audio drivers from this link?
https://www.msi.com/Motherboard/support/X79A-GD45#down-driver&Win10%2064
