Author Topic: MSI fm2-a55m-p33 and 2133mhz ram overclocking  (Read 271 times)
charalamposkontogiorgosTopic starter
« on: 19-July-19, 06:31:55 »
i have the msi fm2-a55m-p33 mobo and i want to put an 2133mhz ram.
At the manual it says that supports 2133mhz ram only if the system is overclocked.
At the BIOS it has an OC Genie II profile that allows you to overclock the system
and at this profile menu it says that "DRAM max frequency" is 1866, so how can i put an 2133mhz ram and the system work?
Chike
  • MAJOR GENERAL
Re: MSI fm2-a55m-p33 and 2133mhz ram overclocking
« Reply #1 on: 19-July-19, 07:47:36 »
The 2133* (*OC) only means that the 2133 is not a standard for this platform, and you need to overclock the memory.
Depends on what memory model you are using, in standard mode see if it has a 2133 XMP profile, f not you will have to overclock it manually, both clock and timings.
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
SSD: 1. Samsung PM981 512GB, 2.  Samsung 840 EVO 120GB
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #2 on: 19-July-19, 08:28:48 »
I have put a 1600mhz memory and i have enable the XMP profile.If i put a 2133mhz memory (with XMP enabled) will it works?
Chike
  • MAJOR GENERAL
« Reply #3 on: 19-July-19, 10:07:19 »
I don't know, does it?
What is current DRAM frequency after you save and reboot?
CPU: i5-4670k
« Reply #4 on: 19-July-19, 12:01:38 »
The DRAM frequency is 1600Mhz with XMP enabled.
Chike
  • MAJOR GENERAL
« Reply #5 on: 19-July-19, 14:36:00 »
Can you attach a CPU-Z text report (about tab), and BIOS OC screen (F12)?
CPU: i5-4670k
« Reply #6 on: 19-July-19, 17:10:35 »
* CPU-Z report.txt (71.7 kB - downloaded 15 times.)
Chike
  • MAJOR GENERAL
« Reply #7 on: 19-July-19, 19:18:56 »
BIOS current memory frequency is 1333, but CPU-z show 1600 so the BIOS screen must have been taken  before you saved the setting.
This memory is rated to be 1600, the 1866 is the  maximum supported standard by the CPU.
Is it possible to overclock it to 2133? I don't know, 1866 is more feasible.
Not worth the trouble though, very little benefit from memory overclock.
CPU: i5-4670k
« Reply #8 on: 20-July-19, 02:04:09 »
Ok, thank you for your time and your effort :)
