Author Topic: VBIOS request for RX 580 ARMOR OC 4G  (Read 365 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
pcm720Topic starter
« on: 19-July-19, 13:41:37 »
Hello!
Can you send me the latest VBIOS for RX 580 ARMOR OC 4G?
S/N1: 602-V341-410B1708015685
CHK: EAB
Thanks!
  • 微星科技
Re: VBIOS request for RX 580 ARMOR OC 4G
« Reply #1 on: 19-July-19, 13:59:37 »
Well, what Version do you have now? Without knowing what you have we can't tell if there is an update.
Windows 10 Pro
MSI MAG BUNKER Case
pcm720Topic starter
« Reply #2 on: 19-July-19, 14:07:15 »
Current BIOS is TV341MH.671, if I'm not mistaken
Marked as best answer by pcm720 on 20-July-19, 01:32:58
  • 微星科技
Ok, there is an update. The latest vbios for this card is TV341MH.674: https://forum-en.msi.com/index.php?topic=298592.msg1682154#msg1682154
Windows 10 Pro
MSI MAG BUNKER Case
pcm720Topic starter
« Reply #4 on: 19-July-19, 14:16:35 »
Thank you very much!
  • 微星科技
Windows 10 Pro
MSI MAG BUNKER Case
