Author Topic: B450 A Pro Motherboard BIOS button  (Read 445 times)
lovelyyounglady1993Topic starter
« on: 19-July-19, 21:08:25 »
Hello. I'm trying to use the bios flashback to update the bios to make it compatible with Ryzen 3200G. However, when I try to do the button, nothing happens (not even an LED). I plugged everything in correctly and the PSU is on but I can't do it. I flashed a USB drive (64 GB) to FAT32 and used the correct BIOS. I don't understand what I'm doing wrong.
CPU: Ryzen 3 3200G
RAM: 16GB Ballistik Sport LT DDR4-3000
PSU: Corsair RM750x
MOBO: MSI B450-A PRO
SSD: Samsung 860 EVO 1TB
COOLER: Cooler Master Hyper Evo 212 Black
CASE: DIYPC Vanguard-V8-RGB
Chike
  • MAJOR GENERAL
  • Online Online
Re: B450 A Pro Motherboard BIOS button
« Reply #1 on: 19-July-19, 21:25:16 »
Did you rename the BIOS file to  MSI.ROM?
Not sure about the flash drive size, have you a smaller one?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
SSD: 1. Samsung PM981 512GB, 2.  Samsung 840 EVO 120GB
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #2 on: 19-July-19, 21:34:17 »
I used a 16GB drive and it seems to be working.
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
« Reply #3 on: 20-July-19, 00:40:44 »
I updated the BIOS but the computer still doesn't boot up unless I do the BIOS flashback. What am I doing wrong?
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
Chike
  • MAJOR GENERAL
  • Online Online
« Reply #4 on: 20-July-19, 01:05:03 »
Can't understand what you are saying.
Does it boot or does it not?
CPU: i5-4670k
« Reply #5 on: 20-July-19, 01:07:03 »
Sorry. When I try to turn it on normally, nothing.
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
Chike
  • MAJOR GENERAL
  • Online Online
« Reply #6 on: 20-July-19, 01:58:46 »
You mean the only thing that does work is flashing the BIOS with the flash BIOS button?
CPU: i5-4670k
« Reply #7 on: 20-July-19, 05:32:57 »
Pretty much
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
« Reply #8 on: 20-July-19, 11:28:47 »
I found why it doesn't boot on. It now does but there's no picture and my peripherals such as keyboard don't work
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
Chike
  • MAJOR GENERAL
  • Online Online
« Reply #9 on: 20-July-19, 12:02:58 »
What was it?
Please follow >>Posting Guide<< to fill your forum signature that will help users assisting you.
CPU: i5-4670k
« Reply #10 on: 20-July-19, 12:31:23 »
It turns out I accidentally put the power and reset cable in the wrong place. I powered on but no picture and my accessories wouldn't work. So I reset the BIOS using the jumper and now the board won't respond at all. Do you think I may have gotten a dud?
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
Chike
  • MAJOR GENERAL
  • Online Online
« Reply #11 on: 20-July-19, 12:52:57 »
I think you need to fill your forum signature with your hardware specs.
You removed the jumper I hope, PSU is on?
Personally  I test new build outside the case first, on a table/cardboard.
CPU: i5-4670k
« Reply #12 on: 20-July-19, 13:01:40 »
Yes and yes.
CPU: Ryzen 3 3200G
PSU: Corsair RM750x
Chike
  • MAJOR GENERAL
  • Online Online
« Reply #13 on: 20-July-19, 15:29:31 »
I suggest to bench test it outside the case, on table and/or cardboard, but don't put it on the anti-static bag.
Use jus one memory module. Is the buzzer connected?
CPU: i5-4670k
