Author Topic: MSI Z77A-G43 - Dual Channel RAM Issue  (Read 1054 times)
crying.silenceTopic starter
  • CORPORAL
« on: 20-July-19, 07:05:16 »
So here goes.
I've never gone to more than 16GB of RAM. And yes for the longest time, I never used slots 1 & 2. In short, I never got to use the dual-channel feature of my board.
So now I tried. And I've seen this in the forums a lot so I was a little sad because it feels like it will never be solved or it may just be my mobo.
PROBLEM: Any single or 2 sticks of RAM I place on slots 1 & 2 keeps my PC rebooting infinitely. Single RAM works fine on either or both of slots 3 & 4.
WHAT I'VE TRIED (based on what I got here too):
1) Checked the bent pins of my CPU socket: none.
2) Tried different RAM sticks: no change
3) Lowered frequency to 1333 via BIOS: no change
4) Updated BIOS to 2.13 (official from site) then cleared CMOS: no change
RAM: Crucial 1600 1.35V (I am currently in single channel mode for both sticks)
PROCIE: I7-2700K
Could you point me to either the answer that's been done similar to my case or if there are steps I can still do to make it work.
Please do note that I am not very technical but with enough instructions, I may be able to figure it out.
Thanks in advance!
Marked as best answer by crying.silence on 23-July-19, 15:34:28
badboy2k
Re: MSI Z77A-G43 - Dual Channel RAM Issue
« Reply #1 on: 20-July-19, 07:17:10 »
if your CPU socket is good and your RAM works if its been there with no RAM in the slots 3 and 4 for a long time its very likely that the slots are dirty inside them so if you can get a hold of a Can of Compressed air and give each of them 2 slots a good blast of air along its whole length and then see if you can get it to post?
if the above fails then more then likely you will need to try this:
if you have access to any high % isopropyl alcohol give the bottom of your CPU a clean across its pads as it is possible some of the pins if you accidentally touched them that there is a thin film of oil over some pads making them not make a good electrical contact?
Cooler: corsair H100 cooler
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #2 on: 20-July-19, 07:21:20 »
Unfortunately, it sounds like a mobo with DIMM slots problem (probability 40%) or a CPU with a bad controller (60%)! :undecided:
Plug only 1 RAM stick in DIMMA2 (2nd DIMM slot from CPU) and do a clear CMOS:
- Power off PSU, unplug the power cord and wait that all mobo's leds light off.
- Either
    . short JBAT1 during at least 20s
      (if you have not a jumper cap, use something like a screwdriver but be cautious to touch only the 2 pins of JBAT1) or
    . remove the battery cell during 15mn.
- Plug the power cord and power on.
- Choose to use default values when asked.
If problem remains, try with another CPU should help to diagnose.
Hoping it shall help,
:hat tip:
  • CORPORAL
« Reply #3 on: 20-July-19, 11:25:20 »
when you say bottom of your CPU, this is the actual procie right? :) sorry if i sounded stupid with that question. but i will try step 1 first since step 2 is kinda tedious for me to do (i still have a hyper 212x cooler).
  • CORPORAL
« Reply #4 on: 20-July-19, 11:28:41 »
- Either
:hat tip:
oh sorry about my previous reply. i didn't know i could quote this way. :P will do this along with suggestion 1 of badboy2k.
Thanks to you both!
badboy2k
« Reply #5 on: 20-July-19, 11:43:46 »
when you say bottom of your CPU, this is the actual procie right?  sorry if i sounded stupid with that question. but i will try step 1 first since step 2 is kinda tedious for me to do (i still have a hyper 212x cooler).
what i mean is these:
clean them as if you touched and of them its very possible you can get the oil off your fingers onto them that can meke them make very poor contact with the Pins in the CPU socket.
Chike
  • GENERAL
« Reply #6 on: 20-July-19, 11:54:58 »
Have you tried a DIMM2 & DIMM4 or DIMM1 & DIMM3 configuraton?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
  • CORPORAL
« Reply #7 on: 20-July-19, 16:14:22 »
yup. one of the 1st i tried.
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #8 on: 20-July-19, 16:22:45 »
Have you done:
1/ Plug only 1 RAM stick in DIMMA2 (2nd DIMM slot from CPU) and do a clear CMOS.
2/ If problem remains, try with another CPU should help to diagnose.
Result?
:hat tip:
  • CORPORAL
« Reply #9 on: 22-July-19, 05:41:41 »
so I've done this: still the same :(
  • CORPORAL
« Reply #10 on: 22-July-19, 05:43:35 »
Have you done:Result?
:hat tip:
I've done this too: no change either.
Does this mean those slots are really dead? :(
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #11 on: 22-July-19, 06:27:09 »
That is pc does not post when there is only 1 RAM stick in DIMMA2, right? Same result with only only DIMMA1 populated?
After all the previous tests, culprit could be either the mobo having bad DIMMA1+2 slots (probability 70%) or the CPU having a bad memory controller (30%)!
Really sorry for this bad news.
Have a good day,
:hat tip:
  • CORPORAL
« Reply #12 on: 22-July-19, 07:03:22 »
That is pc does not post when there is only 1 RAM stick in DIMMA2, right? Same result with only only DIMMA1 populated?After all the previous tests, culprit could be either the mobo having bad DIMMA1+2 slots (probability 70%) or the CPU having a bad memory controller (30%)!
Have a good day,
:hat tip:
That is pc does not post when there is only 1 RAM stick in DIMMA2, right? Same result with only only DIMMA1 populated? - > Yes. Whether DIMM 1 or 2 are populated, it just goes to infinite reboot.
The procie however, I tried on another mobo and it works fine, even in dual channel mode.
So it is the slots then. :(
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #13 on: 22-July-19, 07:41:55 »
  • CORPORAL
« Reply #14 on: 25-July-19, 04:38:45 »
UPDATE:
So I had my friend try my motherboard just for the heck of it and he was able to use the RAM slots with no problem. :(
He was even able to stuck in 4 sticks and it still worked fine.
So it's not the motherboard.
If my RAM sticks work fine on DIMM slots 3 & 4 and on another board then it's not the RAM.
My procie works fine on another board too.
What is it then??? :'(
Please help me figure this out.
Chike
  • GENERAL
« Reply #15 on: 25-July-19, 04:58:33 »
Your case maybe.
Try it out the case on a wood table or cardboard.
CPU: i5-4670k
  • CORPORAL
« Reply #16 on: 25-July-19, 05:08:10 »
Your case maybe.
Oh when I did all my testing on the mobo, it was on top of a plain, cardboard box.
I do this most of the time so I could easily add/remove components when testing.
Chike
  • GENERAL
« Reply #17 on: 25-July-19, 05:15:48 »
How did your friend test it, same CPU and RAM?
CPU: i5-4670k
  • CORPORAL
« Reply #18 on: 25-July-19, 05:19:29 »
Different CPU (i3-3220), different RAM (1 pc 2GB + 3 pcs 4GB, Kingston, 1333).
Chike
  • GENERAL
« Reply #19 on: 25-July-19, 05:35:10 »
The best thing would be to test it with your RAM too, and your CPU with his RAM.
Did you try different combinations of RAM in the 2 slots? (stick 1 n slot 2 stick 2 in slot 4, then swap the sticks)
we know it's not the socket, have you inspected the CPU pads?
CPU: i5-4670k
  • CORPORAL
« Reply #20 on: 25-July-19, 05:41:32 »
I'm not sure if I can still try that (his CPU on mine or my CPU in his) in the near future as my friend doesn't live near my place.
Yes, different combos: like only 1 in slots 1-4, 2 sticks in either pair of slots, and 4 sticks
Yes, they look fine, no scratches, dents, or even some sort of weird color or darkening on it. I did follow the advise to wipe it off with a high percentage alcohol but to no avail :(
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #21 on: 25-July-19, 06:46:05 »
UPDATE:
Previously, I said:
"After all the previous tests, culprit could be either the mobo having bad DIMMA1+2 slots (probability 70%) or the CPU having a bad memory controller (30%)!"
So the only remaining suspect is CPU!
Have a good day,
:hat tip:
  • CORPORAL
« Reply #22 on: 25-July-19, 07:04:37 »
Have a good day,
:hat tip:
I'm sorry if I'm missing the point here but... the same procie works on a mATX Dell board that also has 4 RAM slots. It works on that board with or without using dual channel using the SAME sticks of RAM.
rbleroy91
  • GENERAL
  • RBL_FR
« Reply #23 on: 25-July-19, 07:07:22 »
To verify, borrow the CPU your friend has used to test your mobo.
Good luck,
:hat tip:
  • CORPORAL
« Reply #24 on: 04-August-19, 04:51:56 »
Hi guys! Sorry I was out for a long time. I didn't have access to my PC and was swamped with work.
Anyway, so I know this may be weird but what I was able to do instead was borrow another person's MSI Z77A and used my procie and RAM on it ... and well, it worked.
Frankly, this is VERY WEIRD as it seems like there's nothing wrong with my procie or RAM and it seems nothing is wrong with my mobo either.
Sadly, this also meant I ended up buying a new mobo instead because I really needed to use my PC again.
Thanks for all the help everyone!
