Author Topic: BIOS Request for 2080 TI Seahawk EK X  (Read 185 times)
allainpiquiTopic starter
« on: 20-July-19, 13:35:35 »
Good morning MSI Team,
I'm currently using the 2080 TI Seahawk EK x, and I'm looking for the latest BIO.
my S/N# S/N: 602-V371-69ST1812000354
BIO's Version: 90.02.17.00.2C
Thanks
  • T9246ED, Бивша комета
  • Administrator
Re: BIOS Request for 2080 TI Seahawk EK X
« Reply #1 on: 20-July-19, 14:11:45 »
see here how to check for bios version
https://forum-en.msi.com/index.php?topic=167763.0
« Reply #2 on: 20-July-19, 15:47:07 »
Hi Svet,
Bio's version MSINV371MH.192
  • 微星科技
« Reply #3 on: 20-July-19, 16:58:18 »
As you are using NV371MH.192 there is an update. Latest is NV371MH.194, it is attached.
note that you need to rename the unpacked file NV371MH.194 to .rom (e.g. 194.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 194.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 194.rom
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #4 on: 20-July-19, 17:03:23 »
:biggthumbsup: thanks
  • 微星科技
« Reply #5 on: 21-July-19, 04:21:59 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
