Author Topic: New purchase today. Battery/A/C-charge LED does not illuminate.  (Read 447 times)
calypsoartTopic starter
I purchased a GS75 Stealth today at Best Buy.  However, after plugining it in the LED for battery/charge does not light. Am I missing something, or do I need to return it?
RaiderGamer
  • LIEUTENANT COLONEL
i have raider and my bat led does not light plugged in or unplugged, it only lights when charging
wifi light is on cuz im on wifi and hard drive light is blinking from hdd activity
i dont have steelseries engine or scm installed
if your getting none of those lights at all then try updating bios and ec firmware and resetting ec.
otherwise exchange it
make sure you check everything on the laptop in the first week and exchange it if anything is wrong
check every port and check the screen to see how bad the backlight bleed is, and benchmark it etc...
https://www.userbenchmark.com
this bench might require an external display to bench the nvidia gpu
https://www.pcdecrapifier.com/
personally i would do a clean install of windows and drivers too
https://www.microsoft.com/en-ca/software-download/windows10
https://steelseries.com/engine
here is some good video players:
https://potplayer.daum.net/
or
https://get.videolan.org/vlc/3.0.7.1/win64/vlc-3.0.7.1-win64.exe
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
https://www.msi.com/Laptop/GS75-Stealth-8SX/Overview
http://download.msi.com/archive/mnu_exe/nb/17G1_v1.0_English.zip
In Canada Call MSI @ 1-888-447-6564
Mon-Fri 5:00AM-4:00AM PST (Weekend and Holiday closed)
Note: RMA, Customer Service, Technical Support
Global 1-800 listings https://www.msi.com/page/hot-line
RaiderGamer
on for battery use and slow blinking for charging would have been more intuitive
the lights on the raider and apache are facing downwards and almost impossible to see, basically useless
"Battery LED goes out when it is fully charged or when the AC/DC adapter is disconnected."
AC is currently disconnected. No LED. I'm going to let the battery drain to see if it light amber as in the manual. If not then I assume that mean the light is dead and I'll return the machine.
or
I haven't delved deeply into the machine quite yet, but there is a lot of stuff on it that I don't want. Assuming I was to do a clean Windows install, is there any other specific software that came on  the machine--other than SteelSeries 3--I should put back?
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
All drives, firmware and apps that are in the MSI Driver & App Center.
Oh ya ... You need the driver & app center.
RaiderGamer
clean install windows, then install then new graphics driver then run windows update which will take care of everything else
after that its just details
Ok. Ran the battery down to 10%. No Amber LED as the manual states. When I plugged in the A/C at that batterly level, it did come on. I'm running the MSI battery calibration now to what that does.
RaiderGamer
u can change settings here to get battery lower then 10%
WƧI ꓵƨԍʁ Էoʁnw
  • MAJOR GENERAL
Return it for a refund or exchange....
Don't do a repair on this, it will be a problem later on even if they managed to fix it.
