Author Topic: Register my Super 2060 Graphics Card  (Read 170 times)
djf343Topic starter
« on: 21-July-19, 14:10:37 »
Who decided to put the number(CHK) on the part of the new super card in a spot where you insert it to motherboard?
Why would I register a product before I install it and make sure it is working!
Now I have to take the card out to get to number!!
Serial#,invoice and photo of UPC should be enough to just register a product.
Thank you MSI!!!
  • 微星科技
Re: Register my Super 2060 Graphics Card
« Reply #1 on: 21-July-19, 14:54:43 »
You are not contacting MSI here. >>How to contact MSI.<<
Windows 10 Pro
MSI MAG BUNKER Case
