Author Topic: MB MSI X570A-Pro Can't use WD Black 750 MVMe full speed PCIe Gen 3 X4  (Read 1253 times)
saiyparnsTopic starter
SyStem
Ryzen 5 2600
MSI X570A-Pro
WD Black SN750 250 GB
Team Group 8*2 3200
M2_1 Max Speed Pcie Gen3 x2
M2_2 Max Speed Pcie Gen3 x4
Please help find the cause.
AUTMrBird
  • CORPORAL
I have the same issue with 2 Samsung 970 EVO NVMe 1TB:
M2_1 @ PCIe 3.0 x2 = 1700MB/s (specificiation is PCIe 3.0 x4 with Ryzen 2nd Gen!!!)
M2_2 @ PCIe 3.0 4x = 3400MB/s
CPU: Ryzen 7 2700X
Mainboard: MSI MPG X570 Gaming Edge WIFI @ Bios 7C37c12
Help is highly appreciated!!! :welcome:
AUTMrBird
  • CORPORAL
SyStem
Ryzen 5 2600
MSI X570A-Pro
Team Group 8*2 3200
Here is the solution:
https://forum-en.msi.com/index.php?topic=322687.0
  • T9246ED
  • Administrator
here is the proper version for this board with this issue fixed:
https://drive.google.com/file/d/1Xac_xNm_2G8ajgJ-nEC3sjGJ4EbWfXfP/view?usp=sharing
Thank for support. :-))
AUTMrBird
  • CORPORAL
Hi Svet,
is there also a proper version for the MSI MPG X570 Gaming Pro Carbon WiFi for the same issue?
Kind regards!
  • T9246ED
  • Administrator
@AUTMrBird
with which BIOS version you have this issue with your board?
AUTMrBird
  • CORPORAL
@AUTMrBird
Hi Svet,
I have this issue with Bios Version 1.0 and 1.1 downloaded from the MSI support area https://de.msi.com/Motherboard/support/MPG-X570-GAMING-PRO-CARBON-WIFI and I also tried v1.22 from the MSI FTP server which has the same issue!
The M2_1 is just shown as PCIe Gen. 3 x2 - this results in half the speed with Read: 1779 MB/s Write: 1509 MB/s.
The other M2_2 slot works fine with PCIe Gen. 3 x4 and 3400MB/s.
The specification of the mainboard is PCIe Gen. 3 x4 with a Ryzen 7 2700X on both M2 slots!
CPU: Ryzen 7 2700X
Mainboard: MSI MPG X570 Gaming Pro Carbon Wifi with Bios 1.22
NVMe: 2x Samsung SSD 970 EVO 1TB with latest firmware
Kind regards!
AUTMrBird
  • CORPORAL
use this one:
https://drive.google.com/file/d/1vWe4mD-_9gNVYxzZ6m2f_-r2b0Sj3M79/view?usp=sharing
Thanks, now both M2s are working with PCIe 3.0 x4! :pompom:
Result:
M2_1 read 3520 MB/s, write 2485 MB/s
M2_2 read 3150 MB/s, write 2406 MB/s
The M2_2 on the X570 chipset is slower than the M2_1 on the processor! I had a similar result with the MSI MPG X570 Gaming Edge mainboard.
Why is there such a big difference? Whats wrong with the chipset?
