Author Topic: MSI MPG X570 Gaming Edge WIFI M2_1 NVMe runs only at half speed PCIe 3.0 x2!!!  (Read 3812 times)
This topic contains a post which is marked as Best Answer. Press here if you would like to see it.
AUTMrBirdTopic starter
  • CORPORAL
I have a issue with my new MSI MPG X570 Gaming Edge WIFI:
M2_1 @ PCIe 3.0 x2 = 1700MB/s (specificiation in the manual is PCIe 3.0 x4 with Ryzen 2nd Gen!!!)
M2_2 @ PCIe 3.0 4x = 3400MB/s
CPU: Ryzen 7 2700X
Mainboard: MSI MPG X570 Gaming Edge WIFI @ Bios 7C37c12
NVMe: 2x Samsung 970 EVO 1TB
Help is highly appreciated!!!
montyac
  • MAJOR
You are correct that both M2 slots are x4. Have you try to switch the NVME drives?
  • CORPORAL
Yes I tried to switch the 2 NVMe drives and it is the same result - M2_1 is running @ PCIe 3.0 x2
What I also tried is clearing the CMOS - same result.
And I also flashed the Bios back to the previous version xxx.11 and cleared the CMOS - same result.
Now I have a brandnew mainboard not meeting the specs.
montyac
  • MAJOR
You can contact MSI support. Maybe the board needs a bios upgrade. If they know of the problem and it's correctable, you can wait . If not then replace the board with a different brand.
  • CORPORAL
Yes I already contacted the MSI support, no response until now. When I do not get a solution within one week, I have to change to another brand.
I feel really sad being a beta tester for a new product not working as specified!
Chike
  • GENERAL
Yes you must ASAP.
I have a questions though, if there were no tools to tell you, would you be able to tell the difference?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
  • CORPORAL
Yes you must ASAP.
Could you please describe your question, I am sorry I do not understand what you mean.
Chike
  • GENERAL
Do you feel one is slower than the other?
I myself was disappointed to find out my M.2 is only capable to deliver around 800MB/s, so I bought a M.2 to PCIe adapter card only to fid the only difference I see is in drive temperature, so I put it back in the M.2 slot.
CPU: i5-4670k
LBJistherealchamp
  • MAJOR
Hello, I have a issue with my new MSI MPG X570 Gaming Edge WIFI: M2_1 @ PCIe 3.0 x2 = 1700MB/s (specificiation in the manual is PCIe 3.0 x4 with Ryzen 2nd Gen!!!) M2_2 @ PCIe 3.0 4x = 3400MB/s CPU: Ryzen 7 2700X Mainboard: MSI MPG X570 Gaming Edge WIFI @ Bios 7C37c12 NVMe: 2x Samsung 970 EVO 1TB Help is highly appreciated!!!
This is a known issue when using a Pinnacle CPU on the X570 motherboard.
Probably have to wait for a BIOS update.
Marked as best answer by AUTMrBird on 01-August-19, 09:17:14
  • T9246ED
  • Administrator
  • CORPORAL
have a try this new BIOS:
https://www.dropbox.com/s/pk3llcxxpae13mm/E7C37AMS.134?dl=0
s
Thank you very much Svet, this is exactly what I needed!!! :agrees:
Actual results after updating BIOS to V1.34:
M2_1 @ PCIe 3.0 x4 = Read: 3282MB/s, Write: 2471MB/s
M2_2 @ PCIe 3.0 4x = Read: 3542MB/s, Write: 2482MB/s
Do you know why the M2_1 is around 300MB/s slower than the M2_2?
pandaz
  • MAJOR
which particular M.2 are you using? Did you install the Windows 10 in the M.2?
have you tried to run the Crystal Diskmark 3 times and see if the result is always the same?
rbleroy91
  • RBL_FR
M2_1 is directly managed by the CPU and M2_2 is through the X570 chipset:
That can explain.
To finish, some remark:
- Verify the firmware of your 970 EVO (use >>Samsung Magician<<), there is a recently published update.
- Do not omit to install >>Samsung NVMe Drivers<< and to activate Overprovisonning. That would improve SSD performance and health.
Have a good day,
:hat tip:
limzhihao89
Hi hi do you have the bios for x570 gaming Pro carbon wifi? Exactly same issue as TS using 2700 and Samsung 960 evo 250GB.
jounihelle
You can find new (beta?) BIOS for your board at http://msi-ftp.de:8080/main.html
Just hit "login" and search under /BIOS/X570
I believe 7B93_122.zip should be for x570 gaming Pro carbon wifi
limzhihao89
Hey thanks for this link. Tried it but so far no luck on it. Still showing up as x2 with disappointing read write speed on both crystal mark and samsung magician. Guess waiting for the next bios and shall try out on m2_2
pandaz
  • MAJOR
So you are using Pinnacle 2700 CPU and Samsung Evo 250G?    what score result for Crystal Diskmark did you see when comparing M2_1 and M2_2???
Did you install windows in your M.2?   did you have other test peripherals use in your system?
limzhihao89
Yes 2700 and Samsung evo 960
Results yielded 1800/1400 on crystal mark and samsung magician.
Yet to try m2_2, will try it later. Hopefully can get x4 speed.
One other hdd on sata. One gtx 1060 on first pcie slot.
  • CORPORAL
use this one, I got it from Svet (Admin):
https://drive.google.com/file/d/1vWe4mD-_9gNVYxzZ6m2f_-r2b0Sj3M79/view?usp=sharing
Now both M2s are working with PCIe 3.0 x4! :pompom:
Result with 2 Samsung 970 EVO:
M2_1 read 3520 MB/s, write 2485 MB/s
M2_2 read 3150 MB/s, write 2406 MB/s
The M2_2 on the X570 chipset is slower than the M2_1 on the processor! I had a similar result with the MSI MPG X570 Gaming Edge mainboard as you can see above.
Why is there such a big difference? Whats "wrong" with the chipset?
Topo
  • STAFF SERGEANT
I have exactly the same problem on my MSI Z370 PC PRO motherboard!
Any solution?
Motherboard: MSI Z370 PC PRO
CPU: i7-9700K
Cooler: Scythe SCMG-5100 Mugen 5
Memory: 32GB HyperX Predator DDR4 3200 MHz RGB
GPU: MSI GeForce GTX 1070Ti AERO
M.2: Samsung 970 EVO M.2 512GB NVMe SSD
SSD: Crucial CT250MX200 SATA SSD
HDD: 4x WD BLACK 4TB
DVDRW: Plextor PX-716
Audio: Creative X-Fi Titanium Fatal1ty
TV PCI Card: Hauppauge HVR-4000
PSU: Corsair RM850x
Case: Lian-Li PC-7FNW + Phanteks RGB
OS: Windows 10 Pro 1909 64-bit / Windows 7 Pro 64-bit
rbleroy91
  • RBL_FR
1/ Unplug the M2 drive, clean its contacts and blow on the slot. Plug back the drive. Do a claer CMOS:
- Power off PSU, unplug the power cord and wait that all mobo's leds light off.
- Either
    . short JBAT1 during at least 20s
      (if you have not a jumper cap, use something like a screwdriver but be cautious to touch only the 2 pins of JBAT1) or
    . remove the battery cell during 15mn.
- Plug the power cord and power on.
  Enable "SETTINGS \ Advanced \ Windows OS Configuration \ Windows 10 WHQL Support"; change nothing else at this time.
Same result?
2/ Same result with the 2 M2 slots?
3/ What is the bios version? OS?
Have a good day,
:hat tip:
Topo
  • STAFF SERGEANT
Thank you for your advice.
I never thought it could be a bios problem but I hope you are right. I am currently on 7B49v18 (Windows 10+7) but I downloaded the latest bios 7B49v19 but haven't updated it yet because every bios update resets all the settings to default and I will have to do them all again including the fan curves which usually takes me a long time!
Anyway when I do I will swap the slots again, clean the contacts and I will let you know the outcome.
CPU: i7-9700K
PSU: Corsair RM850x
Topo
  • STAFF SERGEANT
- Either
Same result?
Have a good day,
:hat tip:
Sorry for the late reply! I done all this and updated to the latest bios 7B49v19 but still the same problem!
My Samsung 970 EVO NVME drive runs at only 2x speed in the M2_1 slot but runs at 4x when installed in the M2_2 slot! So its obviously not a windows, drivers or settings  problem and its most probably a Bios issue. Everything else runs as expected. Does anyone has a bios that I can try?
CPU: i7-9700K
PSU: Corsair RM850x
plutomate
  • MAJOR GENERAL
wut kinda tool you use to check bandwidth? or you're running crystaldiskmark that gives unexpected low score? and your CPU model?
Topo
  • STAFF SERGEANT
I can tell the bandwidth from many utilities but I rely mainly on Samsung Magician software there in drive information tells me the Interface info of the M.2 drive if its 2x or 4x (PCIe Gen. 3 x2). Also if I do any bandwidth test in Samsung Magician or CrystalDiskMark or As SSD or any other the read speed does not go more than 1700 MB/s when the interface speed is 2x but its 3500 MB/s on 4x which is what is expected from this drive. My CPU is i7-9700K and all my PC spec is in my signature.
CPU: i7-9700K
PSU: Corsair RM850x
plutomate
  • MAJOR GENERAL
Can you flash BIOS with M-Flash again? and update the SSD firmware in Samsung magician. btw, it's better to just open a new thread to avoid confusion (because topic is X570 chipset board)
