Author Topic: Audio / 5.1 / 7.1 issue?  (Read 162 times)
jsmith33Topic starter
« on: 08-August-19, 15:58:03 »
Hi All -
I have a P67-GD65 (B3) mobo and am using the onboard sound..
I just recently purchased Cloud Alpha headphones - and am curious which port I should be using - is the front audio out the same as the one on the back / onboard?  If the back - will I get the 5.1 srs with the single audio jack?  Would I benefit from a USB sound card?
Thanks,
Jason
  • T9246ED
  • Administrator
Re: Audio / 5.1 / 7.1 issue?
« Reply #1 on: 08-August-19, 19:42:26 »
the audio on the headphones is just a stereo jack
you can't transfer multiple channels trough this.
else you can do enable some virtual 5.1/7.1 surround features eventually.
