Author Topic: overclock ram with MSI z390  (Read 1348 times)
klein.elieTopic starter
« on: 09-August-19, 10:06:56 »
I just had a new pc a month ago now.
I took a motherboard MSI MPG Z390 GAMING EDGE AC and this ram G.Skill Trident Z DDR4 RGB 4 x 8GB 3000 MHz CASE 16
the problem is that in the task manager I see that the ram is at 2666 MHz while I bought it for 3000....
Apparently I have to go do something in the bios to activate a "profile xmp" to put the 3000 Mhz.
I'm really a computer novice so I'm a little scared to go into the bios and venture there knowing nothing .... I found what to do on other sites but sometimes it's not really clear
and as I'm afraid of making a mistake I come to you hoping you could guide me?
What are the steps I need to do?
Thank you for your help!
Elie.
pandaz
  • MAJOR
Re: overclock ram with MSI z390
« Reply #1 on: 11-September-19, 04:50:48 »
basically you just need to set XMP to enabled...that's all :)
R3V0
« Reply #2 on: 14-September-19, 18:45:24 »
set the xmp on via bios
Chike
  • GENERAL
« Reply #3 on: 14-September-19, 20:05:28 »
When you enter bios (by spamming the del/delete key during post) you get the bios screen, the second round button on the left, click it to turn it on.
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #4 on: 24-September-19, 08:25:20 »
So i just have to turn on the xmp button?  i don't have to put 3000 mhz somewhere?
When i come to menu xmp button is already turned on
Chike
  • GENERAL
« Reply #5 on: 24-September-19, 13:25:02 »
If it's already turned on than it is already running at 3000mhz
Go to oc menu make sure xmp profile is selected.
Post a screen capture of CPU-Z memory and spd tab.
You can open multiple instances of cpu-z to have both tabs in the same capture.
Perhaps bios screen as well (F12 to save to usd flash drive)
CPU: i5-4670k
Chike
  • GENERAL
« Reply #7 on: 24-September-19, 15:21:39 »
XMP is enable but you can see under it dram frequency is set to 2666, change it to auto.
CPU: i5-4670k
« Reply #8 on: 26-September-19, 07:56:20 »
It's okay thank you!
