Author Topic: GS65-004 2nd power supply  (Read 292 times)
dotanuki001Topic starter
« on: 10-August-19, 13:56:25 »
I have a GS65-004 and it came with the 230W power supply.  I travel with it and I was thinking of getting a 180W power supply will with that work with the laptop? or is there a lighter weight version of the 230W power supply?
sascha.nagl
  • SERGEANT
Re: GS65-004 2nd power supply
« Reply #1 on: 15-August-19, 07:24:01 »
Normally a 180Watt Power Supply should be sufficient for your notebook. It is very important to use the same 19.5 Volt then the original power supply. Maybe if you play game the notebook will not load up your battery, but should be enough for using the computer
Ryzen 3700X
MSI MPG Gaming Pro Carbon WIFI
Balistix Elite DDR3600MHz
MSI Gaming X GTX 1060 6GB
Samsung EVO 1TB NVME SSD
MSI MPG Sekira 500G Case
