Author Topic: X570 Gaming Edge Wifi Ez Debug DRAM light on  (Read 666 times)
-V-Topic starter
« on: 11-August-19, 03:47:13 »
Hello everyone,
I don't know if this is the right place to write about the little problem I'm facing right now.
I bought an MSI X570 Gaming Edge Wifi motherboard and after everything is plugged in, the Ez Debug LED shines bright on the DRAM saying DRAM failed or not detected.
I followed the motherboard manual and my RAM are correctly slotted like in the manual.
I tried to clear the CMOS, tried to follow the FLASH BIOS Manual instruction but I don't know if the Flash Bios really worked as the LED never power off.
I also saw that my RAM (F4-3200C15D-16GTZKW) does not appear in the RAM compatibility list on the MSI product page but the same RAM with a different CAS (F4-3200C16D-16GTZKW) in on the list.
I don't really know what's going on or why the same RAM with a different CAS would not work for this motherboard.
I'm looking for tips as I'm really stuck right here !
Thank you :)
edit: RAM model
Chike
  • GENERAL
  • Online Online
Re: X570 Gaming Edge Wifi Ez Debug DRAM light on
« Reply #1 on: 11-August-19, 04:06:11 »
You wrote F4-3200C15D-16GTZKW twice.
On G.Skil site this codel is compatible with intel platforms only.
F4-3200C16D-16GTZKW and F4-3200C14D-16GTZKW are listet compatible with both AMD and intel platforms.
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
-V-Topic starter
« Reply #2 on: 11-August-19, 04:21:53 »
Oops, bad copy/paste, I edit my previous post.
Thank you for the answer, so I need to send back my RAM and change it as it is not compatible with AMD platform. Good find !
Thank you
Chike
  • GENERAL
  • Online Online
« Reply #3 on: 11-August-19, 04:29:25 »
Just make sure your replacement is compatible with your motherboard+cou combo.
CPU: i5-4670k
-V-Topic starter
« Reply #4 on: 11-August-19, 04:54:45 »
I'll make sure of that, thank you ! :)
Thread can be closed ;)
