Author Topic: super charger  (Read 337 times)
wricker11Topic starter
super charger
« on: 24-August-19, 20:21:49 »
I have a MSI X470 Gaming Plus motherboard. How do I use the SUPER CHARGER to charge andriod devices? My e-mail is [REMOVED].
sascha.nagl
  • SERGEANT
Re: super charger
« Reply #1 on: 25-August-19, 06:04:19 »
you have to connect JUSB1 with the front USB. Only this supports super charging
The JUSB1 (red mark) connector supports the new Super Charger technology.
from MSI, the extra fast charger for your mobile phone or other devices.
with the USB port. To enable this feature, please install
the MSI SuperCharger application on your computer. Once the SuperCharger
application is activated, the JUSB1 connector will use the data channels as additional
release energy channels in order to charge the connected devices particularly quickly.
Please note that when the Super-Charger application is activated, the
Data transmission and synchronization via the JUSB1 connector does not work.
To groove the JUSB3 port as a normal USB 2.0 port, switch
Please select the SuperCharger application. If the computer is in standby or
Sleep mode (S3 / S4 / S5), the Super Charger mode will automatically be set to
activated.
Ryzen 3700X
MSI MPG Gaming Pro Carbon WIFI
Balistix Elite DDR3600MHz
MSI Gaming X GTX 1060 6GB
Samsung EVO 1TB NVME SSD
MSI MPG Sekira 500G Case
Re: super charger
« Reply #2 on: 27-August-19, 11:11:56 »
Is there anything else I need to do in Windows 10 to get Super Charger to work with Android products?
